Well... like in the title, "Does anyone have a cut/transform effect for VDJ8?"
geposted Mon 11 May 15 @ 11:33 am
geposted Mon 11 May 15 @ 11:54 am
hello everyone , allways when i enter the page for transform effect i do not see anything!!! just its writing on the top ADD-ON !!!!!!
ANY HELP PLEASE........ I REALLY NEED THIS TRANSFORM EFFECT FOR VIRTUAL DJ 8 ....
THANKS A LOT....
THANKS A LOT....
geposted Wed 16 May 18 @ 9:45 am
A similar effect called cut has been built-in now
It's included in the latest 2 public builds
geposted Wed 16 May 18 @ 10:32 am
thanks for your answer... can you share the link please...
BEST REGARDS
BEST REGARDS
geposted Wed 16 May 18 @ 10:47 am
http://www.virtualdj.com/download/index.html
Download and install latest VirtualDJ build from the link above.
Now look on your effects. You should see "Cut" effect. It's the same effect, only that now it's native inside the software
geposted Wed 16 May 18 @ 11:08 am
