Hi,
A few time ago i use iwall with vdj 7 and it works pretty cool
Now with vdj i had problems with i wall in the beginning of using it in vdj 8
Is iwall 3.7 now working ok ?
Are there vjd8 users with good use off Iwall?
geposted Sat 23 May 15 @ 9:54 am
I use iWall with Telly Visuals and VirtualDJ 8 without issue.
geposted Sat 23 May 15 @ 4:28 pm
Ok, what version of Iwall and telly Visuals do you use?
geposted Sat 23 May 15 @ 4:43 pm
iWall 3.7 and TellyVisuals 1.71
Can you describe what problems your having?
I did a hangout presentation and getting all of the different applications and how to work with them together. Hopefully I can help you out.
geposted Sat 23 May 15 @ 5:01 pm
Hi, i have now iwall 3.7 and telly visuals 1.71 plus, wen i sent a tekst to iwall i see the text in the chatbox coming but not on my extern beamerscreen, that is the problem?..?.
geposted Sat 23 May 15 @ 6:27 pm
Does Telly show iwall connected with the status icon in the configuration window?
Do other panels from Telly show up on your screen?
Can you post control panel pictures from Telly, and iwall?
geposted Sat 23 May 15 @ 6:32 pm
anche io ho lo stesso problema.. come posso risolverlo?
geposted Wed 12 Aug 15 @ 6:26 pm
