Forum: Old versions
Topic: Syphon output at 720p?
Hello, I have installed the syphon servers for both vdj7 and 8. They both "work" but the video output is only around 401x229.
Is there a way to up that to 720p? I double checked, and Yes, I'm running a 720p file. I searched every line of the preference on both 7 and 8 and cannot find any way to change it.
Thanks for any and all help
geposted Mon 29 Jun 15 @ 1:08 am
The output resolution is determined by the size of your output video window in VDJ, because that is what the video engine is working to. Resize it up to 1280x720. You can then even close it and it will retain that resolution.
geposted Mon 29 Jun 15 @ 5:21 pm
jreal13Home userMember since 2018
Donde puedo descargar syphon
geposted Sat 10 Nov 18 @ 4:39 am
