Forum: VirtualDJ Skins
Topic: How can I change the waveform colors in my skin for VDJ8?
Is it possible to change the multicolored waveforms in one-colored ones (one color for each deck) in vdjscript 8, and if so, how can I do that?
In VDJ7 you could turn them on or off, but in VDJ8 this option is no longer there...
geposted Fri 17 Jul 15 @ 9:12 am
Options > coloredWaveforms
If you search options advanced you will find most things there.
geposted Fri 17 Jul 15 @ 9:16 am
I did that, but to no effect: the waveforms are still multicolored...
geposted Fri 17 Jul 15 @ 9:25 am
Which waveforms are you talking about, the deck ones will change if you select the monochrome option.
geposted Fri 17 Jul 15 @ 9:28 am
Sorry for the confusion. I'm talking about the rhythm waveform...
geposted Fri 17 Jul 15 @ 10:18 am
Click here and change from "horizontal scratch wave" to "default wave"
geposted Fri 17 Jul 15 @ 10:32 am
Yeah, I guess that would be the only way... but I really wanted to see the four waveforms side by side. Thanks anyway, Kradcliffe!!!
geposted Fri 17 Jul 15 @ 11:00 am
@ any of the moderators:
DJDAD explained to me that posts about skins and vdjscript should go in the skinning forum.
Please, feel free to move this post there.
I apologize for posting in the wrong section.
geposted Sat 25 Jul 15 @ 3:13 am
