Forum: VirtualDJ Skins
Topic: Skin info ?
WWDJdkPRO InfinityMember since 2008
If i want to make my skin, show the name of the author, next to the VDJ logo, what code should i use in my skin to let i read the general skin author name, set in the first line ?
I know i just kan make a format=" XXX", but is it not possible to let i read the skin's general author/name/ ect.
geposted Mon 27 Jul 15 @ 7:29 am
what you see in the first line of a skin such as .. author="" Comment="" etc is what you see in the "ABOUT" section in Settings-->INTERFACE tab when you put your mouse over a skin.
If you want to display something on the skin itself (text, image, logo etc), you need to use
<textzone> and format="your Text"
or
<visual> with <off> graphics you want to show.
geposted Mon 27 Jul 15 @ 7:58 am
I know..
Was hoping there was some kind of "Get_" command, like get_controller_name, that was able to read the skin info to display it on the skin itself.
But guess i just have to work with the format="xx"
geposted Mon 27 Jul 15 @ 8:03 am
