Is there a similar function in VDJ8 like there is in VDJ7 where you could go into the settings and update the database and remove any old files from the database?
geposted Fri 31 Jul 15 @ 12:06 am
click on the little dot on the left bottom window pane above the two A (which is the font size).
geposted Fri 31 Jul 15 @ 12:32 am
Wow, totally overlooked that.... thanks!!
geposted Fri 31 Jul 15 @ 1:07 am
