any ideas?
W10
asus gtx 560
17 2600 cpu @3.40
4gig ram
64 bit os
this is what it only shows
W10
asus gtx 560
17 2600 cpu @3.40
4gig ram
64 bit os
geposted Fri 31 Jul 15 @ 2:16 am
Check the Video driver - looks like you are using a MS generic one instead of the manufacturer one.
geposted Fri 31 Jul 15 @ 2:20 am
iv tried to update my drivers from GeForce.com and I keep getting this
geposted Fri 31 Jul 15 @ 2:23 am
maybe this is why my graphics card is spinning like it wants to take off...
I'm using the HDMI from the motherboard, that's why I cant work out how to fix this spinning situation maybe
haha, found the mini hdmi to hdmi connection, brb
geposted Fri 31 Jul 15 @ 2:29 am
geposted Fri 31 Jul 15 @ 4:38 am
my gig machine has the download but i havent installed it yet... i want to try W10 with vdj8 b4 i do my gig machine
geposted Fri 31 Jul 15 @ 6:31 am
i know the problem now with my Video Card... it needs TWO 6 pin power plugs and my power supply has ONE 6 pin plug... damn video card with two 6 pins
geposted Fri 31 Jul 15 @ 10:25 am
What the...?
How is it even possible to run without the second connector?
Anyway, I don't think that this causes the problem that only a part of VDJ is displayed.
geposted Fri 31 Jul 15 @ 10:43 am
iv disconected the gtx 560 now and i have full view of VDJ8
i did a you tube search on my vid card and it mentioned i need two 6 pin connectors
geposted Fri 31 Jul 15 @ 10:51 am
all i did was restart my computer then the full screen reset
geposted Sat 08 Aug 15 @ 12:30 pm
Found these two connection on the bottom of all cables and connected my 2nd power cable to my vid card.
after an update driver for vid card, my card is working fine.
I have a full vission of V8.
geposted Thu 13 Aug 15 @ 10:22 am
And yes, its a two 6 point power system card
geposted Thu 13 Aug 15 @ 12:14 pm
