How do I check what Build I am on and when a new one comes out will I automatically be notified or do I need to run a check somewhere in the software?
geposted Fri 31 Jul 15 @ 3:15 pm
Go to the setting then you can find on the top of the page
geposted Fri 31 Jul 15 @ 5:00 pm
When you turn on VDJ you get a message that your software has ben updated would you like to download? (or something like that).
I always wants to it to update so I clicked download. It would be nice if it tell what has been updated or what will be updated to should I select download.
I just clicked download the update but I do not know what has been updated.
geposted Mon 03 Aug 15 @ 2:20 pm
@ ohshit
I think that if you look here you can find out what's been updated in the latest public build, it's a long thread so scroll down to the bottom;
http://www.virtualdj.com/forums/189620/VirtualDJ_8_bug-report_Forum/Builds_History.html
geposted Mon 03 Aug 15 @ 2:40 pm
I would be careful with any updates.
Before going on my working machine I test them on my backup laptop.
In the past I have had problems, it is unclear if it was something I did, or the updates.
Updates come for all types of software.
Last time I updated everything at once..stupid.
When it went wrong I did not know why.
My updates are turned off in the options, and I only update when I'm ready.
geposted Mon 03 Aug 15 @ 2:47 pm
i cant get the denon mc6000mk2 cue buttons to work any ideas ta
geposted Mon 03 Aug 15 @ 3:47 pm
I'm sorry itsdiscodave, your question has nothing to do with this topic. Please don't hijack threads. Thank you.
geposted Mon 03 Aug 15 @ 4:06 pm
It's off topic but I'd be glad to help, I'd need a few minutes to get my decks out of the way, and start my mc6000.
The mc6000 is approx equal to the mk2.
I'd be surprised if we could not sort it out, do you want to try ?
I mean now, in the next 30 min.
Hm start a new post, and let me know if you want my help, many here will help you!
geposted Mon 03 Aug 15 @ 4:11 pm
