Hi,
I have a DDj-WEGO and just upgraded from the VDJ LE to the Pro and now the Jog Rim will no longer beatmatch but search as if i was using the Jog touch. I have had a look at the mappings but couldn't figure out how to revert the change. Please help.
Thanks.
Thanks.
geposted Sun 02 Aug 15 @ 11:24 pm
I'm not a Wego user, but have you looked at the manual for the unit? There may be a "shift" button to change the behavior of the jog.
geposted Mon 03 Aug 15 @ 8:12 am
have you got a 'vinyl' or 'scratch' button enabled?
geposted Mon 03 Aug 15 @ 12:52 pm
G'Day sport,
I use the WeGo a lot and hav'nt had this problem, so I've got a couple of questions in order to help you out with this problem;
vdj 7 or 8?
Which build?
Default or custom mapping?
Which skin?
vdj 7 or 8?
Which build?
Which skin?
geposted Mon 03 Aug 15 @ 1:08 pm
