Topic: Serato dj/Vdj8 Tweaks for Windows 10
https://www.youtube.com/watch?v=W5EF-4N-IvE Note as of late i have been using vdj 8 more and more
the bpm alwas reads .not true in serato
I removed the image because it was promoting another software, and was not necessary. You're a smart guy, clearly you could have used a Virtual DJ logo, to post on a Virtual DJ forum? I left the link intact. AMAHM
geposted Fri 28 Aug 15 @ 1:32 am
Wouldn't it be easier to just wait till its officially supported by any software you use??
I personally won't be updating till its supported but Thanks for the tips eitherway......
geposted Fri 28 Aug 15 @ 3:04 pm
I fail to see what this video has to do with VirtualDJ?
VirtualDJ does not use .NET framework, so no need to fiddle around with that.
The other tweaks to disable task bar transparency and animations are also mostly personal preferences. I doubt it has a noticeable impact on performance.
geposted Fri 28 Aug 15 @ 3:19 pm
