Apologies if this has been covered.
Been looking at having a go at live broadcasting to Mixify (I currently do this with Ustream with live video/audio successfully) and I understand that I can do it directly through VDJ8. Seems pretty straightforward in the software broadcast panel.
What I wanted to check is that I am using 2 Denon SC2900s and a DN-X1600 and in the sound configuration do I need to set anything in particular for this to work? As I am using 2 CD players as midi controllers and an outboard mixer (as the soundcard) do I need to set anything in particular in the audio settings panel like record/booth etc to feed audio back into v8?
Any thoughts?
Any thoughts?
geposted Mon 31 Aug 15 @ 11:45 am
If you can record it with vdj8 built in recording it will broadcast.
Mixify works well with vdj 8 have tested it myself
I am guessing you will need to set up a loop back with an external mixer
geposted Mon 31 Aug 15 @ 12:53 pm
Cheers Wickedmix,
I figured as much. Just wasn't sure if VDJ would broadcast the loop back (record in) as opposed to the master in the software.
geposted Mon 31 Aug 15 @ 1:03 pm
If you use the external mixer with deck 1,2 outputs in your audio config, then you need to add a record input there for the loopback
geposted Mon 31 Aug 15 @ 1:51 pm
Thanks Adion,
So any of the available left...eg, 1,2 or 7,8?
I use 3,4 and 5,6 on the DN-X1600
geposted Mon 31 Aug 15 @ 6:30 pm
