Forum: Old versions
Topic: Rane SL1 not being read
I can not figure out what I am doing or not doing. I have seen one or two posts about this but no reply's at all. For windows I just installed the driver but I don't have the SL1 driver for mac and can't seem to find it at all. What am I missing here that I can't get the SL1 to read for VDJ. Works just fine for Serato.
geposted Sat 03 Oct 15 @ 5:02 am
AsTheDJPRO InfinityMember since 2008
I tried it also and No luck maybe you need SL2 the SL1 is 1stGeneration/OldS.w
geposted Tue 06 Oct 15 @ 2:23 pm
I did more research and from way way back I guess a Mac and SL1 will not work with VDJ. There is no way around this. So for VDJ to work you will have to have an SL2 or above. Kinda sucks cuz I figured someone would have created a patch or update for this by now but nope. Have to spend another $1000 to use VDJ and the tables with an SL2. Works fine with the Numark Controller I have and that is my gig machine so that's the important part.
geposted Wed 07 Oct 15 @ 10:06 pm
Well Just checking if there has been a update or something to see if the Rane sl1 to work with VDj yet
geposted Tue 20 Dec 16 @ 12:43 am
