hi guys this is my first ttime i post topic. i use virtual dj 7.4.1 build 482 in a 5year old acer laptop windows 7 with a ddj ergo controller and never had any problems !
i've just bought a new hp envy that i have upgraded from windows 8 to windows 10 and i always get the same message when i try to use the sound effects.
i also have to mention thati get a a lot of distortions in the sound while i try to mix.before you suggest anything that is already written ihave read it all and nothing helped.i even copied and pasted the hole file from the acer!i really want help!!!!!
geposted Tue 06 Oct 15 @ 4:36 pm
Upgrade to the newest V7 and report back.
geposted Tue 06 Oct 15 @ 5:17 pm
wasn't aware a home user could use a controller in V7 .... maybe it's LE version?
also my ergo works fine in windows 10 but i am using vdj8 ... if you have a license i would switch to vdj8 since they are still upgrading it to work with new stuff unlike vdj7
geposted Tue 06 Oct 15 @ 7:57 pm
