Forum: VirtualDJ Skins
Topic: new skin - the thing (based on Virtual DJ 8 - Pads for DDJ-SP1) - Page: 1
new video-view (added slider/reminder/peaks on VUs)
Added:
- Automix-Panel at top (only if Automix on) to show the next song + skip/edit-button
- New Beatphaser
- button for 2/4 deck
- button for audio/video
- button for browser-zoom
- button for hide songinfo
- master fx
- custom buttons on deck
- custom buttons downside (to toggle between large and small ones)
- progressbar
Edit: - cue-nr on deck
- button keylock on all decks
- all vu's in stereo with peakmeter
- cue-points on wheel
- cue-countdown on wheels (beat-down)
- different logos, if beatcounter on jog is set to off
- beatcounter on jogs
- reminder on wheels
- wheelmode-button over the jogs
- cf-modes in all views
- reminder on mixer in all views
- record-section
- get food ;o)
- prelisten
and a lot of options to select (e.g. scratch-background on/of, quantize etc):
The thing is uploaded today, status: pending.
geposted Sun 25 Oct 15 @ 4:23 pm
looks nice thanks
geposted Sun 25 Oct 15 @ 4:34 pm
New wave-view: Split Selected /left&Right
Also:
- get built under the VDJ-Logo
- CBG-Edits (on/off by Options-Menu)
geposted Mon 26 Oct 15 @ 6:48 am
geposted Mon 26 Oct 15 @ 10:30 pm
avoid adding skin elements at the bottom (after the Browser) or else graphics will not be displayed properly when the skin is resized.
A solution would be to add 2 breaklines in your xml code (e.g. breakline="800" breakline2="1040") but give it a try before adding this.
geposted Mon 26 Oct 15 @ 11:06 pm
How to add breaklines? And where to place? One before and the second after browser? I can't find something about this in the skin-wiki, sorry.
Edit:
<group name="battery" x="1851" y="1035">
<visual visibility="is_battery">
<Tooltip></Tooltip>
<size width="58" height="26"/>
<pos x="+0" y="+10"/>
<off x="595" y="1390"/>
</visual>
<visual type="linear" source="get_battery" orientation="horizontal" visibility="is_battery">
<Tooltip>Battery Indicator</Tooltip>
<size width="43" height="17"/>
<pos x="+4" y="+15"/>
<off x="599" y="1395"/>
<on x="659" y="1395"/>
</visual>
<visual visibility="not is_battery">
<Tooltip>AC Power</Tooltip>
<off x="595" y="1419"/>
</visual>
</group>
<button action="getfood" class="custom_neutral">
<pos x="1851--5-46-10-44" y="1035+10"/>
<tooltip>Get Food</tooltip>
<icon x="183" y="1514" height="16" width="24" dx="" dy="" />
<!-- <text size="16" color="#aaaaaa" align="center" format="HIDE" /> -->
</button>
<!-- BROWSER -->
<browser visibility="var '$browser' 0">
<size width="1900-2" height="404+35-31+138-35"/>
<pos x="11" y="665-35+31-138"/>
</browser>
<browser visibility="var '$browser' 1">
<size width="1900-2" height="404+35-31+138-35+205"/>
<pos x="11" y="665-35+31-138-205"/>
</browser>
</Skin>
The browser is the last element and skin works fine? Or did I missed something? Thanks for your advice ;o)
geposted Mon 26 Oct 15 @ 11:15 pm
I meant the last displayed element, not the last element in the xml.
Breakline is used if u want to specify a line that the skin will be resized from that. By default VDJ will use the starting line of the <browser>
Breaklines are set at the top of the skin.
See the default Tablet skin.
geposted Mon 26 Oct 15 @ 11:30 pm
done and updated. Hope it's allright now.
geposted Tue 27 Oct 15 @ 1:54 am
New Version is pending review.
Change-log:
- fix progressbars
- fix vu deck 3 in 4-deck Video-view
- add breaklines
geposted Wed 28 Oct 15 @ 4:34 pm
geposted Fri 30 Oct 15 @ 1:59 pm
New Version 1.6. is online.
Thanks to DJDad (I guess) ;o)
geposted Mon 02 Nov 15 @ 6:29 pm
New update is pending review.
Changes and adds
  • Cover on decks added
  • 4 saved loops added
  • smart loop as textbutton
  • loop roll as textbutton
  • beatbar + beatcounter added
  • Visuals for selected deck + master-deck
  • more custom buttons
  • broadcast button added
  • eq-kill buttons added
Done some fixes in the menue. The Power-icons only appears on win OS (works only with win-os!).
Hope you like it. Enjoy ;o)
geposted Sun 20 Mar 16 @ 6:03 pm
update still pending review...
geposted Fri 25 Mar 16 @ 8:09 pm
geposted Mon 28 Mar 16 @ 7:17 pm
FruitPRO InfinityMember since 2003
Good job !
I like the wheel rotation handling the loops, very smart :)
geposted Tue 29 Mar 16 @ 2:23 am
Thank you :-)
geposted Tue 29 Mar 16 @ 5:31 am
- 3 different CBG-views on scratch-waves
- 3 different pitchreset-speeds
- Counter-reset On/Off as option
- sampler-mode button on deck (if padmode=sampler)
- sampler-record button on deck (if padmode=sampler)
- cue-lock on deck (if padmode=cue)
- cue-edit on deck (if padmode=cue)
- show broadcast-message on top
- show record-message on top
- fixed some small issues
stay tuned ;o)
Some screenshots:
geposted Sat 16 Apr 16 @ 9:44 am
@music234 the English translation of "Modus" is "Mode" :-)
geposted Sat 16 Apr 16 @ 11:06 am
Damm!
OK, I'll fix this ;o)
Done und uploaded ;o)
geposted Sat 16 Apr 16 @ 11:42 am
....still not approved yet....
geposted Sat 23 Apr 16 @ 7:11 am
47%
