Topic: Recommended VST plugins
krn3kiPRO InfinityMember since 2014
There are several VST plugins out there and since native VDJ plugins can't event remotely compare with Pioneer's DJM or Remix station, I was wondering which VSTs do you find useful and actually use them on gigs?
geposted Tue 01 Dec 15 @ 12:18 pm
geposted Tue 01 Dec 15 @ 1:21 pm
geposted Tue 01 Dec 15 @ 2:04 pm
lincol2PRO InfinityMember since 2011
love this!
geposted Tue 01 Dec 15 @ 3:07 pm
I have copied the content from C:\Program Files\Common Files\Steinberg\VST2 to C:\Users\Username\Documents\VirtualDJ\Plugins\SoundEffect and I get Error This plugin does not seem compatible with VirtualDJ 8 when I try to use Turnado with VDJ8.1.
geposted Tue 01 Dec 15 @ 7:59 pm
You need to use the 32-bit plugin with VDJ on Windows, not the 64-bit.
geposted Tue 01 Dec 15 @ 8:15 pm
That did the trick, thanks. So what are you favorite effects/subeffects in Turnado? I still cannot find those who are mostly used by popular EDM DJs (Axwell, Martin Garrix, Alesso, Nick Romero etc.) though.
geposted Tue 01 Dec 15 @ 9:30 pm
i doubt those djs use anything you can't find on a pioneer mixer or pioneer FX unit if they use anything at all....
what FX exactly are you looking for? if we knew that maybe could be more help.
geposted Tue 01 Dec 15 @ 10:35 pm
@wickedmix
Can you recommend a FX plugin that can create sound "buildups" or 'risers"?
geposted Tue 29 Dec 15 @ 1:13 pm
geposted Tue 29 Dec 15 @ 5:18 pm
i'd guess something more tonal would be the desire.
geposted Tue 29 Dec 15 @ 9:09 pm
SBDJ wrote :
Sweep uses a filtered manual/synced white noise buildup
I agree however a vst with a gater/cut on that sweep will do something else. Also a tone buildup sound (maybe this is what Locodog is referring to) with the same gater/cut and filter effect I am looking for in a vst plugin that works with VDJ8.
geposted Tue 29 Dec 15 @ 10:08 pm
i am not sure what exactly you want to do but turnado has a tone generator and a gate mess about with it you might find what you are looking for
it has so many settings when you dig into it it does most everything
geposted Wed 30 Dec 15 @ 12:09 am
