Forum: VirtualDJ 8.1 Technical Support
Topic: Exclusive Audio Access Popping sounds
I bought Denon MC4000 controller today, I am running VDJ 8.1 Pro Build 2587.1086 on a Dell quad core 8 gb running windows 8.1. Everything was plug and play and worked fantastic. I was messing around and noticed that the Exclusive Audio Access was turned off. Probably by me a few months ago. I turned it on and then suddenly I was getting strange popping sounds from the Main out, and the Head phone jack. I disconnected the controller and just used the head phone jack on my laptop and the sound was fine. turn off Exclusive audio access and everything woks great. Any suggestions? thanks.
Edit. All drivers are up to date, I also tried changing the USB cable.
Edit. firmware is up to date, I have tried changing latency with no luck
geposted Tue 08 Dec 15 @ 5:03 am
What is the latency? You can manually increase the latency for exclusive audio mode by setting the 'latency' option yourself. Try various values like 128, 256, 512 and see at which point you don't get the noises anymore.
geposted Tue 08 Dec 15 @ 5:28 am
Latency is set to Automatic. I tried those three #'s with no change. I'm currently working on upgrading the Firmware.
geposted Tue 08 Dec 15 @ 5:43 am
Was there a solution to this problem? I'm having the same issues.
geposted Mon 02 Apr 18 @ 12:50 am
Me, too. Same problem.
geposted Sat 05 May 18 @ 7:56 pm
Read the first post...
geposted Sat 05 May 18 @ 8:01 pm
