Hi
Some odd problem here,..
HP Pavilion DV7 with Intel HD3000 and Radeon HD6700M latest Lashcat drivers CCC 15.11 Beta UnifL_v1.0
Open VDJ and the standard output is Intel HD and I can't seem to get it to work with Radeon, earlier with Windows 8 you could chose whitch one you would like to use but now I can't choose.
In CCC i've chosen High Power for VDJ8.1 but that also doesn't make any difference.
Ok , now I'm stuck Help?
Bios chosen between Fixed and the other one but no succes...
Thanks in advance
VDJ Rob Huurman - Rojo Sound & Light
16000 Remastered DVD Clips and counting...
Thanks in advance
geposted Thu 10 Dec 15 @ 1:52 pm
I believe you can right click on the preview window and select the output. Not the video output screen that you drag to a monitor, but the mater out preview between the decks.
geposted Thu 17 Dec 15 @ 7:20 am
No that doesn't work , it still gives the Intel as output also in Virtualdj Intell as output but I've checked Google and it seems like Windows 10 can't handle switchable graphics.
geposted Sat 26 Dec 15 @ 11:30 am
setings -> video -> forcefullscreen 1
test this please
Breaenzu
test this please
Breaenzu
geposted Sat 26 Dec 15 @ 4:21 pm
Which problem do you have with the integrated graphics?
geposted Sat 26 Dec 15 @ 4:31 pm
with my intel hd4600 i have load freezes and the output quality is bad
geposted Sat 26 Dec 15 @ 4:42 pm
Do you have the option DXVA activated in the VirtualDJ options? If so try to switch it off.
That's a wrong statement.
Fixed is the option to choose in the bios
geposted Sat 26 Dec 15 @ 10:29 pm
None of these options work ,
Output is still Intel HD instead of AMD
Further investigation on the internet suggests that Windows 10 just can't handle switchable graphics
My settings are correct , my Bios settings are Fixed so also correct.
In VirtualDJ it stays on Intel HD output
geposted Mon 25 Jan 16 @ 9:52 am
Don't know about AMD, but when I select nVidia in their control panel, the tray icon shows that virtual dj is using it, so it's not a problem of Windows 10 in general.
How did you check if it is using integrated or the discrete gpu?
geposted Mon 25 Jan 16 @ 11:54 am
geposted Mon 25 Jan 16 @ 11:41 pm
yep as I stated earlier mine is Intel HD 3000 and so not supported in Win10
geposted Tue 26 Jan 16 @ 3:13 pm
I am having the same problem. I have an Alienware 15 R2 with Intel and Radeon graphics. CCC is set for VDJ to run high performance. Radeon is selected as the video driver in VDJ options window. I use the fruit skin and when I click the out button it lists only Intel. I use extend desktop for the 2nd monitor but this setting was set by right click desktop and selecting display settings set to extend. By doing this I believe it extends the Intel desktop. I do not have an option in CCC TO extend this desktop. Either way, VDJ is using the Intel (on board) graphics card and not the Radeon. Still searching for a solution.
geposted Tue 18 Jul 17 @ 5:41 pm
The video outputs always run through the Intel, which is why the Intel is listed as your external monitor. The rendering is probably done with your amd though.
What problems do you have exactly?
geposted Wed 19 Jul 17 @ 2:36 am
