Forum: VirtualDJ 8.1 Technical Support
Topic: How do i remove a plugin
perryrobControlleristMember since 2003
The wahwah plugin for version 8 doesnt work, however the one for version 7 does. I deleted the version 8 from plugin folder but its still showing up. I have 2 wah wahh showing in my effect list. How di i get rid or uninstall the version 8 one
geposted Mon 18 Jan 16 @ 3:11 pm
you can't remove the Native_Plugin(s), however you can move it to the IGNORE section of the sound effects.
want to see what this Native Plugins are, just go to virtual DJ folder under my documents and you see a whole list that you can't remove. Even if you delete this file(s), when VDJ is executed, it will return.
Best, move to the ignore list.
geposted Mon 18 Jan 16 @ 4:01 pm
lincol2PRO InfinityMember since 2011
Where is this "IGNORE section of the sound effects" I do not see it.
geposted Mon 18 Jan 16 @ 4:34 pm
right click the one you wish to ignore and select ignore :-)
geposted Mon 18 Jan 16 @ 4:43 pm
thank you , cool
geposted Mon 18 Jan 16 @ 9:54 pm
thanks i saw that, much appreciated
geposted Wed 20 Jan 16 @ 10:34 pm
freppaPRO InfinityMember since 2002
Is it possible to remove native plugins that I dont want from the map that its installed in C:/documents/vdj/plugins ?
geposted Thu 21 Jan 16 @ 4:42 pm
No, you cannot remove native plugins.
geposted Thu 21 Jan 16 @ 7:05 pm
GBL16Home userMember since 2017
You have down instruments,vocals...and you download new addons and they do not work. HOW TO DELETE !!!
Go to your Documents ( My documents), VirtualDJ and sampler.In sampler you see winrar files.Do not do these new drums with the name and just delete,and that is it
geposted Wed 18 Oct 17 @ 10:37 am
