Hi All,
I'm wondering if there is a way to map specific samples to pads on a controller. My rig conssits of an APC mini and an Lpad8, among others. I use the APC in default mode, I find that works well and give a lot of flexibility. I use to use the Lpad to controll looping and effects, but I've just upgraded my main controller to a mixtrack pro 3, which has all that ready, so the Lpad is now free for other uses.
What I am hoping to do is to map my fav kicks / claps / drops to the pads and thier volume to the knobs. But Have that stay the same irrespective of which sample set it the active on in VDJ8. I'm thinking either by referring to it by name in the mapping (PAD_1_8 sample "sample_name"), or by set and sample number (PAD_1_8 sampleset 2 sample 3).
Is this possible?
Cheers
Keith
Is this possible?
Cheers
Keith
geposted Mon 08 Feb 16 @ 10:51 am
of course this is possible. if you map a pad use e.g. "sampler 4 play_stop" this action will play the 4th sampler in the currently active slot.
to get detailed informations about the various actions please see here:
http://www.virtualdj.com/wiki/VDJscript_verbs_v8_p2.html
geposted Mon 08 Feb 16 @ 12:15 pm
Thanks RobRoy, the example you gave isn't what I was asking about but looking at the detailed info on the link, I htink I sdhould be able to do what I want wiht a named reference to a specific set and then the sample number.
I'll post my working code here for others when I've had a chance to write and test it.
geposted Mon 08 Feb 16 @ 3:56 pm
perhaps that´s what you mean ?
sampler_bank 1 & sampler "Laugh" play_stop
you have to specify the sampler bank first ... then the sampler you want to use by name or by number
geposted Mon 08 Feb 16 @ 4:31 pm
A few examples.
sampler_pad 'Audio/Saxo'
or
sampler_pad 'Instruments/Kick'
so : sampler_pad 'Sampler_Folder/Sampler_name'
or
geposted Mon 08 Feb 16 @ 5:39 pm
