Is there a way to lower or raise a deck key, and have that key change remain on that deck, until I remove it.
geposted Fri 29 Apr 16 @ 2:52 am
How about change resetkeyonload to no, and map a smart knob to key and move at your leisure.
geposted Fri 29 Apr 16 @ 12:44 pm
Hi O, the resetkeyonload-no doesn't work. Ya load song A, drop the key, load song B, and the key goes back to center, or such, if ya know what I mean. I thought at one time resetkeyonload-no did work, but it doesn't now. But, that would be perfect if it did.
geposted Sat 30 Apr 16 @ 12:10 am
Click on Options, and type in "key". This is what I have, hope it helps you..
geposted Sat 30 Apr 16 @ 12:49 am
Exactly, you can see mine is set to no. It would seem to me if you change the key, and have this set to no, the key would remain changed for each song. Perhaps it just doesn't work that way.
geposted Sat 30 Apr 16 @ 3:37 am
