Forum: VirtualDJ 8.1 Technical Support
Topic: Numark Mixtrack 3 no sound
So I can't get any sound to play with this. I understand it doesn't have a built in soundcard, but I am just trying to mix with my laptop speakers. I hear sound with the controller unplugged, but when plugged in I don't. I have registered the project with Numark, used that to download virtual dj 8 LE and register it to my virtualdj account/license it. What am I missing? Also, why does this forum say Im a home user when I have a license registered to this account?
geposted Fri 06 May 16 @ 9:43 pm
When Mixtrack is plugged, what do you see in the Settings-->AUDIO tab for sound card ? Can you post a screenshot ?
Also what does Window uses as Playback device when Mixtrack is plugged ?
geposted Fri 06 May 16 @ 10:08 pm
Im on a mac and sound output stays on internal speakers in system settings.
for virtual dj in audio -> soundcard, it displays internal soundcard.
If I play a song in itunes or something I can hear that, its only virtual dj.
geposted Fri 06 May 16 @ 10:33 pm
When the controller gets connected, it reports the position of their faders to VirtualDj and the software adjusts its mixer faders to match to the reported ones.
So if any of the Volume of the channel, the Master Volume knob, the Gain etc are at the minimum 0% position or the crossfader is at the other side, you wont be able to hear anything.
geposted Fri 06 May 16 @ 11:13 pm
Wow...thank you. I had the master gain all the way down lol
geposted Fri 06 May 16 @ 11:23 pm
mine still dont wanna sound
geposted Fri 09 Jun 17 @ 5:53 am
