Hello I recently got a DJ set that came with Virtual DJ LE and it works perfectly fine but then I tired using it on my macbook for travel purposes and when I look at my music it only shows the artists while on my windows it shows all songs also I switched the licences to LE and on the side it says click here to use FX and I click there and it simply does not work. I have tried everything including deleting and reinstalling. Please Help, Thanks!
geposted Mon 23 May 16 @ 11:35 am
Please check this comparison chart. Le versions are not full function, so maybe this is the issue. I can't help you with the Mac issue.
geposted Tue 24 May 16 @ 7:02 pm
