Topic: Key Change Not Working Correctly
I have noted that instead of a key change we are getting a speed change.
This is totally NOT cool!
In 8.1 i could change key without affecting the speed.
geposted Tue 07 Jun 16 @ 6:56 am
I don't see this issue. My tempo stays the same even when a do a KEY +12
The video i put up last night on the VDJ FB page, in which I play with keys, also shows that the tempo stays the same:
https://www.facebook.com/klaus.mogensen.96/videos/10154204227149909/
geposted Tue 07 Jun 16 @ 7:54 am
I can assure you that if you listen you will hear the track slow down and speed up, and while there are no visible indications of a change in speed when i run my metronome I can hear it.
geposted Tue 07 Jun 16 @ 10:03 am
Ok, if it's a tiny bit, I can't say that I'm sure. I thought you ment like if you were using a turntable pitch
geposted Tue 07 Jun 16 @ 10:34 am
When I play 2 tracks synchronized and change the key on one they still stay synchronized for me, no drifting here.
geposted Tue 07 Jun 16 @ 10:40 am
Definitely not working properly here you can hear it slowing as you step down and speeding up when you step up
geposted Tue 07 Jun 16 @ 12:53 pm
Can you make a recording or video perhaps?
geposted Tue 07 Jun 16 @ 1:02 pm
Since Last update it seems to be ok.... not sure what it was.
geposted Wed 15 Jun 16 @ 11:19 am
