Hi,
I have a probleem with the new standaard skin in VirtualDJ v8. When I put the skin in tabletmodus then I have not enough space to brows in my files. I can see only 2 to 3 files. Is there a way to change the layout a bit so that the ratio playerpart vs browser part can be changed. I use a laptop having resolution 1366 x 768 (max for my HP 15 inches laptop). If I put an extra display on my laptop (27 inches using 1900 x 1020) then I get the desired ratio, but thsi is not an option when i'm on the move.
I looked in helpfiles, searched through all options but can t find a solution. Please help.
Kind Regards,
Roeland Hartmans
Kind Regards,
Roeland Hartmans
geposted Mon 13 Jun 16 @ 7:39 am
If you have updated VirtualDJ to 8.2 (set earlyAccessUpdates to Yes) , you will notice that the new Tablet default skin offers a Zoom Browser mode (button exists at the bottom-left and top as well)
geposted Mon 13 Jun 16 @ 10:31 am
