Topic: Removing the 'Remix' text from being displayed in the default skin
dcomoPRO InfinityMember since 2012
In the default skin for 8.2, the remix information is displayed next to the title of the song and I'd like to remove that. (Too much information scrolling.)
I checked the .xml and I don't see anything called out to display that.
Any idea on how to remove it?
geposted Thu 16 Jun 16 @ 8:50 pm
have u tried to adjust tracklistformat?
i think that may be it
geposted Thu 16 Jun 16 @ 8:52 pm
Assuming you're using the 2 deck skin, search for "get_remix_after_title" and change to "get_title"
It appears in 4 separate places.
The suggestion above is not the solution.
geposted Thu 16 Jun 16 @ 8:57 pm
I'm using the 4 deck skin. I searched for remix, however I didn't find anything in the .xml.
geposted Thu 16 Jun 16 @ 8:59 pm
The same string is in the 4 deck XML too.
Use PSPad or something similar as it has mass search and replace functionality.
geposted Thu 16 Jun 16 @ 9:01 pm
I'll check again. (I usually use Notepad++.)
geposted Thu 16 Jun 16 @ 9:10 pm
Where does the default skin get placed now that it's 'built-in'? It's definitely not in the skins folder any longer...
geposted Fri 17 Jun 16 @ 1:29 am
Ignore, I found the new export option.
geposted Fri 17 Jun 16 @ 1:32 am
Thanks 'kradcliffe'. Works great!
geposted Fri 17 Jun 16 @ 1:41 am
Cool, glad you're sorted.
geposted Fri 17 Jun 16 @ 7:23 am
