Topic: vdj8.2 pioneer ddj-sr bug [SOLVED]
Hi peeps,
i updated to 8.2 a couple days ago, and found out that the skip function doesnt work anymore.
When pressing shift and turning on the jog wheel the track used to skip forward a lot quicker as compared to only spinning the jog wheel - however with vdj 8.2 the shift function does not work anymore.
Has it changed now or do i need to fix something?
geposted Fri 17 Jun 16 @ 11:54 am
Should be fixed in the latest Early Access build 3272
geposted Tue 21 Jun 16 @ 2:45 pm
it stil does not work tho - can i fix it on my own in the options/setting somewhere?
geposted Wed 22 Jun 16 @ 10:22 am
Build 3272 and factory default mapping ?
geposted Wed 22 Jun 16 @ 3:30 pm
just checked, and yes it is b3272 with default mapping ... how come it works with your controller, but doesnt with mine?
geposted Wed 22 Jun 16 @ 10:33 pm
its still not working - can you guys please fix this.
geposted Mon 27 Jun 16 @ 12:40 pm
Can anyone else check on his DDJ-SR. Here works fine, weird.
geposted Mon 27 Jun 16 @ 1:35 pm
b3286 and its still not working.
geposted Tue 28 Jun 16 @ 12:38 am
When you press SHIFT and move the jog, do you touch the top of the platter ?
geposted Wed 29 Jun 16 @ 7:28 am
shouldnt matter.
Just to make sure, can you delete the file settings.xml from /Documents/VirtualDJ folder , re-launch VirtualDJ 8 and see if it works now ?
geposted Wed 29 Jun 16 @ 8:39 am
@phantom: when i touch the sides of the platter its moving a little quicker than my regular speed, but looks like slow motion / and when i turn on the top of the platter it moves quicker, however it is the same speed with or without adding the shift button.
isnt there anything in the options where i can reconfigurate the shift button?
@dad: i just deleted the file, opened vdj again but i didnt change anything.
geposted Wed 29 Jun 16 @ 9:24 am
please do the following..
Use the 2 Decks default skin and assign a custom button as ..
deck 1 wheel_mode 'search'
Then Hold SHIFT down on the DDJ-SR
Does the Custom button turn on while SHIFT is held down ?
geposted Wed 29 Jun 16 @ 7:20 pm
