For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: how to move from internal to external hard drive without losing cue point's,analyzing track,play list and tags?
Hi to all! can somebody instruct me about how to move from internal to external hard drive? I just wanna use external instead of internal but without losing cue point's,analyzing track,play list and tags? all my files are on internal! if I move all files to external hard drive what I need to do to keep my tags,play list,cue points same as I had them on my internal?
Is this possible? if so please help ......
geposted Sun 19 Jun 16 @ 6:52 pm
if you transfer the files to the external drive using the file browser in VDJ it will transfer cues and stuff as well.
geposted Sun 19 Jun 16 @ 7:37 pm
Thanks! wickedmix........ so everything should work same as on internal?
geposted Mon 20 Jun 16 @ 8:23 am
yes
geposted Mon 20 Jun 16 @ 9:08 am
Thanks very much Wickedmix!
geposted Tue 21 Jun 16 @ 9:47 am
