Buzzing and popping and no sound with 2FX Flanger has buzzing and Filter cuts off when move it after turning on then off,got restarted VDj---8.2 3268/1166
Mac 10.9.5
2.6 Ghz IC i7
8GB 1600
Mac 10.9.5
2.6 Ghz IC i7
8GB 1600
geposted Mon 20 Jun 16 @ 5:46 pm
video with sound
https://youtu.be/E6hAYs3lUaU
geposted Tue 21 Jun 16 @ 3:21 pm
The Flanger FX still not working,the filter fix in 3278
geposted Fri 24 Jun 16 @ 1:32 pm
Your flanger High-pass value seems to be incorrect.
Try to move the slider and see if the value gets back to the normal range. Then possibly a restart of virtualdj will be required to get it working again.
geposted Fri 24 Jun 16 @ 2:00 pm
That not it when I get home I will do a 2nd video were there no back ground sound at work,now it just buzzing when on..
geposted Fri 24 Jun 16 @ 3:18 pm
https://youtu.be/_gi3XA_gCiA
geposted Fri 24 Jun 16 @ 3:44 pm
With the bug in the latest update it's a bit hard to see what the highpass knob is set to.
You can try to go to Documents\VirtualDJ\Plugins and remove native_Flanger.ini to see if that fixes it.
geposted Fri 24 Jun 16 @ 4:06 pm
Yes that fix it maybe from 3202 or 3205+ when it started doing that.Thank You
geposted Fri 24 Jun 16 @ 4:46 pm
