Hi Peeps,
just wanted to record a mix, and found out that the recording function does not work anymore.
i always used the setting "waitforsound" and so when i pressed record, even though the track started playing it didnt recognize any sound - so i switched the setting to "dontwaitforsound" but it still does not recognize any sound. like when i press play it says waiting for sound....
please someone help me fix this issue.
geposted Mon 20 Jun 16 @ 11:12 pm
Works well here. Are you sure you had the Volumes and Gains high enough to get a "clear" sound so that the recording would start ?
Are you using any specific hardware/audio setup so that we can reproduce here ?
geposted Mon 20 Jun 16 @ 11:44 pm
works fine here too.
Windows 7
Windows 7
geposted Tue 21 Jun 16 @ 1:56 am
fixed it - just had a wrong setting for the sound cards.
geposted Tue 21 Jun 16 @ 9:53 am
