I was wondering if you would ever have usb support for I Remote for windows devices. It would be nice to plug my tablet into my computer and use it as a remote screen, Also for some reason My iremote will not connect correctly since the last update, Pleas advise how to fix this issue.
geposted Sun 26 Jun 16 @ 9:20 pm
I can 2nd the fact that there is a problem somewhere for some users with the remote software..
with my user-level diagnostics ive only got as far as saying it something between latest builds / bonjour network / firewall..
but yes a USB connection could help at best of times as the computer can charge the tab during use..
geposted Sun 26 Jun 16 @ 11:53 pm
Yep - me too. Just spent ages updating everything to try to get the IRemote to work without success. I can get it working on by ticking the VDJ7 remote box - so all connections must be there. Any ideas??
geposted Tue 27 Sep 16 @ 9:38 pm
Yup me to, id love to see this able to be used over USB instead of wifi.......
geposted Tue 27 Sep 16 @ 11:07 pm
If you USB tether, you can use the remote over USB.
geposted Wed 28 Sep 16 @ 1:50 pm
