HI, just bought the mixdeck express and really disappointed with the absence of the sync botton. Can anyone help me how to map the CUE button on my mixdeck express to rather serve as the SYNC? i dont know if its possible.
Any little input will help. I use the virtual DJ 7 Pro full.
geposted Mon 27 Jun 16 @ 4:51 am
I have the cd eject buttons mapped to sync button
geposted Mon 27 Jun 16 @ 11:31 am
Just open config, click on mappers tab, select the Mixdeck on the list and press the CUE button.
Once you see it's code on the software replace the current command with "sync" (without the quotes) and you're done
geposted Mon 27 Jun 16 @ 11:42 am
