Topic: Can't Save Playlists
I can't save Playlists or open the playlist "folder" in Virtual DJ. There is a + sign by it. But it won't open and not of my playlists are saving. I tried this in VDJ 7 and 8. Still the same problem.
geposted Wed 29 Jun 16 @ 6:16 pm
Anyone know how to fix this ? I never had this issue before
geposted Wed 29 Jun 16 @ 11:56 pm
Are you using Windows 10 ?
geposted Thu 30 Jun 16 @ 5:09 am
Maybe some security or write protection prevents from saving a file to that Folder ?
check the permissions on /Documents/VirtualDJ/Playlists folder
also see if right-click on the VirtualDJ icon on your desktop->Run as admin helps.
Any Antivirus running in the background ? Try to turn it off and try again.
geposted Thu 30 Jun 16 @ 5:26 am
