I have a numark mix track 3 I turn on the sample keys with the pad mode button and turn sampler on but when I try the same for off it doesn't work
geposted Fri 01 Jul 16 @ 2:51 am
Could be how you have your samples set to play.
There are 4 Modes:
- On/Off - Press for on, press again for off
- Hold - Only plays while the sampler button is pressed
- Stutter - Once started, the loop will play. If you press again, it'll restart. Over and over. With a mouse, a right-click will turn it off
- Unmute - When pressed, it starts to play but silent. When pressed again, it unmutes the sound while you are holding.
There are 4 Modes:
geposted Fri 01 Jul 16 @ 3:28 am
Also SHIFT+PAD always stops the sample
geposted Fri 01 Jul 16 @ 10:07 am
Thanks guys it's not the sound I want off just the keys so that I can use the loop feature right now the sample keys block that because I don't know how to turn the keys off
geposted Fri 01 Jul 16 @ 4:01 pm
http://www.virtualdj.com/documents/Numark%20Mixtrack%203%20-%20VirtualDJ%208%20Operation%20Guide.pdf
Page 7.
Press the pad mode button and then the pads to switch mode
Page 7.
geposted Fri 01 Jul 16 @ 4:33 pm
