Topic: need help vdj stopped showin my music at last nights party!!
so the party was from 5 to 10 and about 9 the music disappeared for a minute and it came back ,but then it happened again .. the screen was stuck" browsing" and i had to use finder to search music then drag song to deck in vdii restarted vdj first chance i got and the songs were there..
this is the second time its happened so thats why I'm posting.. the first time i thought it was a glitch or something but now I'm worried as it happened again and i have a big party this weekend and wedding to do next weekend
i read somewhere about deleting settings (after making a backup of it ) gonna try that any thin else could cause this has this happened to anyone
i didn't get a crash report but i did get one a few weeks ago but forget why..think i was messing with midi settings pn control z2
OS X 10.10.5 yosemite
vdj8.2 b3286
was using traktor timecode vinyl and kontrol z2
thanks in advance
geposted Tue 05 Jul 16 @ 1:33 pm
CannenPRO InfinityMember since 2016
Sometimes that happens if your external hard drive gets disconnected.
Check your USB cable and make sure the port on your computer is clear.
If for one reason or another your cable was loose or moved in the wrong way to cause a disconnection, that could have also caused it.
geposted Tue 05 Jul 16 @ 2:14 pm
it shouldn't of moved .it sit on the shelf of the mixer case plugged directly into computer.
also, i was able to search for music and drag it to vdj so the hd was still connected( also window would pop up saying drive disconnected improperly)
gonna let vdj run today for a few hours and see what happens
geposted Tue 05 Jul 16 @ 3:51 pm
The USB drive getting disconnected happens to me every once in a while and my drive doesn't move either. Could be the bass, or maybe just a loose connection that the bass effects. I'm not sure, but it does happen sometimes.
I don't believe that I've ever had a message that told me the drive had disconnected either.
Just a thought.
geposted Wed 06 Jul 16 @ 6:55 pm
Thanks for the info...it hasnt happened at home but then again i cant really turn up the volume in my neighborhood only when at a venue
i have been rescanning my database since i downloaded the my files plugin and apparently i have like 8000 files not scanned..dont know how but this gonna take some time lol
geposted Wed 06 Jul 16 @ 8:26 pm
UPDATE
so i have vdj browsing/scan I'm going through the My Library folder(which is awesome ) and i goes to click on after folder and nothing shows up .so i try and click on every thing starting with desktop and not one folder will show files or open for subfolders
What do i do besides restart?? this can't happen i have parties all weekend HELP
geposted Fri 08 Jul 16 @ 1:17 am
blckjckPRO InfinityMember since 2008
Now, I don't have a Mac, but the problem seems to be something to do with the drive disconnecting. Not sure if it's failing, a bad cable, going to sleep, etc.
Can you copy a portion of your library to your main drive and see if they stay?
Do you have another USB cable you can try?
Can you check in System Preferences/Energy Saver to see what the USB settings are?
I know in the past OSX had a close command line structure as Linux. With a command terminal open, dmesg would show the current kernel messages. They would show things like disconnects and such. Unfortunately, I do not have a Mac to test that with.
EDIT:
I had a friend test this on OSX 10.11.5
Open the terminal app
then use the following command
sudo dmesg
This will spit out a bunch of text. Run the command repeatedly while your having problems and see if it shows disconnects or read errors on the USB drive.
geposted Fri 08 Jul 16 @ 1:50 am
ok will try that now but i dont think its the external because its not even expanding the desktop or volumes or any other folder ..should i close vdi again ? Also i went o check hard drive and its there so i clicked on eject and its says can't eject because virtualdj is using it
geposted Fri 08 Jul 16 @ 2:46 am
Last login: Thu Jul 7 14:47:00 on console
TarrencricesMBP:~ DJTROCK$ sudo dmesg
Password:
Longterm timer threshold: 1000 ms
Darwin Kernel Version 14.5.0: Mon Jan 11 18:48:35 PST 2016; root:xnu-2782.50.2~1/RELEASE_X86_64
vm_page_bootstrap: 888522 free pages and 151862 wired pages
kext submap [0xffffff7f80a00000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000a00000]
zone leak detection enabled
"vm_compressor_mode" is 4
multiq scheduler config: deep-drain 0, urgent first 1, depth limit 4, band limit 127, sanity check 0
standard timeslicing quantum is 10000 us
standard background quantum is 2500 us
mig_table_max_displ = 13
AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
calling mpo_policy_init for TMSafetyNet
Security policy loaded: Safety net for Time Machine (TMSafetyNet)
calling mpo_policy_init for AMFI
Security policy loaded: Apple Mobile File Integrity (AMFI)
calling mpo_policy_init for Sandbox
Security policy loaded: Seatbelt sandbox policy (Sandbox)
calling mpo_policy_init for Quarantine
Security policy loaded: Quarantine policy (Quarantine)
Copyright (c) 1982, 1986, 1989, 1991, 1993
The Regents of the University of California. All rights reserved.
MAC Framework successfully initialized
using 16384 buffer headers and 10240 cluster IO buffer headers
AppleKeyStore starting (BUILT: Jan 11 2016 18:28:20)
IOAPIC: Version 0x20 Vectors 64:87
ACPI: sleep states S3 S4 S5
AppleIntelCPUPowerManagement: (built 18:21:26 Jan 11 2016) initialization complete
pci (build 18:25:06 Jan 11 2016), flags 0xe3000, pfm64 (36 cpu) 0xf80000000, 0x80000000
[ PCI configuration begin ]
console relocated to 0xf80030000
[ PCI configuration end, bridges 7, devices 17 ]
ARPT cannot assert wake from D3cold
mcache: 2 CPU(s), 64 bytes CPU cache line size
mbinit: done [64 MB total pool size, (42/21) split]
FireWire (OHCI) TI ID 8025 built-in now active, GUID 002332fffe2cc1b4; max speed s800.
rooting via boot-uuid from /chosen: 37622513-0C2C-3A51-9FC5-8EFF41A9D68A
Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
com.apple.AppleFSCompressionTypeZlib kmod start
com.apple.AppleFSCompressionTypeDataless kmod start
com.apple.AppleFSCompressionTypeZlib load succeeded
com.apple.AppleFSCompressionTypeDataless load succeeded
AppleIntelCPUPowerManagementClient: ready
Got boot device = IOService:/AppleACPIPlatformExpert/PCI0/AppleACPIPCI/SATA@1F,2/AppleICH8AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/ST9250315AS Media/IOGUIDPartitionScheme/Untitled@2
BSD root: disk0s2, major 1, minor 2
USBMSC Identifier (non-unique): 574D43315431383835323338 0x1058 0x1140 0x1019, 2
hfs: mounted on device root_device
VM Swap Subsystem is ON
No interval found for . Using 8000000
ath_get_caps[4044] rx chainmask mismatch actual 7 sc_chainmak 0
3.324202: ath_get_caps[4019] tx chainmask mismatch actual 5 sc_chainmak 0
3.326416: Atheros: mac 12.2 phy 8.1 radio 12.0
3.326432: Use hw queue 0 for WME_AC_BE traffic
3.326441: Use hw queue 1 for WME_AC_BK traffic
3.326450: Use hw queue 2 for WME_AC_VI traffic
3.326460: Use hw queue 3 for WME_AC_VO traffic
3.326469: Use hw queue 8 for CAB traffic
3.326477: Use hw queue 9 for beacons
3.326631: wlan_vap_create : enter. devhandle=0x8800f718, opmode=IEEE80211_M_STA, flags=0x1
3.326699: wlan_vap_create : exit. devhandle=0x8800f718, opmode=IEEE80211_M_STA, flags=0x1.
bpfAttach len 88 dlt 127
bpfAttach len 124 dlt 192
bpfAttach len 24 dlt 105
3.326764: ATH tunables:
3.326769: pullmode[1] txringsize[ 256] txsendqsize[1024] reapmin[ 32] reapcount[ 128]
AppleYukon2: Marvell Yukon Gigabit Adapter 88E8055 Singleport Copper SA
AppleYukon2: RxRingSize <= 1024, TxRingSize 256, RX_MAX_LE 1024, TX_MAX_LE 768, ST_MAX_LE 3328
IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
IOGraphics flags 0x43
[IOBluetoothHCIController][start] -- completed
NVDAStartup: Official
**** [IOBluetoothHostControllerUSBTransport][start] -- completed -- result = TRUE -- 0x7800 ****
**** [CSRBluetoothHostControllerUSBTransport][start] -- completed -- 0x7800 ****
[IOBluetoothHCIController][staticBluetoothTransportShowsUp] -- Received Bluetooth Controller register service notification -- 0x7800
NVDANV50HAL loaded and registered
Previous shutdown cause: 5
DSMOS has arrived
AppleLMUController::smcReadKey received error 0x84 when reading key 'ALRV'.
[IOBluetoothHCIController::setConfigState] calling registerService
**** [IOBluetoothHCIController][ProcessBluetoothTransportShowsUpActionWL] -- Connected to the transport successfully -- 0x9100 -- 0xa800 -- 0x7800 ****
AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
en1: channel changed to 1
en1::IO80211Interface::postMessage bssid changed
[IOBluetoothHostControllerUSBTransport][ReceiveInterruptData] -- kIOReturnAborted, data size is 0, but data in buffer -- (data Length = 4, packet length = 6) Data Content:
39.624649: setDISASSOC from ATH_INTERFACE_CLASS disconnectVap
39.624680: switchVap from 1 to 1
39.718367: ath_set_tx_chainmask[7408] sc->sc_config.txchainmask 7 mask 7
39.718390: performCountryCodeOperation: Not connected, scan in progress[0]
en1: BSSID changed to e0:88:5d:e7:8c:d0
en1: channel changed to 149,+1
AirPort: Link Up on en1
40.098760: apple80211Request[10514] Unsupported ioctl 181
40.098777: apple80211Request[10514] Unsupported ioctl 181
AirPort: RSN handshake complete on en1
AppleKeyStore:Sending lock change 0 for handle -501
coreaudiod (map: 0xffffff802af23870) triggered DYLD shared region unnest for map: 0xffffff802af23870, region 0x7fff92000000->0x7fff92200000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
hfs: mounted FreeAgent GoFlex Drive on device disk1s2
en1: 802.11d country code set to 'US '.
en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 36 40 44 48 52 56 60 64 149 153 157 161 165
Sandbox: appleeventsd(49) deny file-read-metadata /Library
Sandbox: appleeventsd(49) deny mach-lookup com.apple.ocspd
process VirtualDJ[462] thread 9051 caught burning CPU!; EXC_RESOURCE supressed due to audio playback
3544.932011: setDISASSOC from ATH_INTERFACE_CLASS disconnectVap
3544.944448: setDISASSOCIATE ****STA SYNC DISASSOC SUCCESS
3544.944470: switchVap from 1 to 1
process VirtualDJ[486] thread 18781 caught burning CPU!; EXC_RESOURCE supressed due to audio playback
process WindowServer[164] caught causing excessive wakeups. EXC_RESOURCE supressed due to audio playback
23041.912506: performCountryCodeOperation: Not connected, scan in progress[0]
en1: channel changed to 60,+1
en1: channel changed to 36,+1
23042.613195: apple80211Request[10514] Unsupported ioctl 181
23042.613207: apple80211Request[10514] Unsupported ioctl 181
23137.985174: setDISASSOCIATE ****STA SYNC DISASSOC SUCCESS
en1: BSSID changed to e0:88:5d:e7:8c:cf
23138.081679: apple80211Request[10514] Unsupported ioctl 181
23138.081691: apple80211Request[10514] Unsupported ioctl 181
23141.308814: setDISASSOCIATE ****STA SYNC DISASSOC SUCCESS
en1: BSSID changed to a0:39:f7:81:71:14
en1: channel changed to 11
23141.388027: apple80211Request[10514] Unsupported ioctl 181
23141.388039: apple80211Request[10514] Unsupported ioctl 181
AirPort: Link Down on en1. Reason 16 (Group Key Handshake timeout).
28639.172744: apple80211Request[10514] Unsupported ioctl 181
28639.172756: apple80211Request[10514] Unsupported ioctl 181
geposted Fri 08 Jul 16 @ 2:49 am
Unfortunately I don't see any time stamps. But, it looks like Sandbox is trying to do something right before VDJ gets messed up.
Can you try without being connected to your network? I am assuming Sandbaox is trying to back up to a network drive.
EDIT: At first I thought Sandbox was part of time capsule because of some posts while searching. I now realize it is a protection service for when apps misbehave.
EDIT2: The more I read it appears sandbox is saying VDJ does not have permision to access the /Library
geposted Fri 08 Jul 16 @ 4:49 am
geposted Fri 08 Jul 16 @ 6:15 am
Looks like it may be a permissions issue. I think that maybe your computer is letting VDJ run, but in a "sandboxed" mode. Meaning, it's cut off from the rest of the system and doesn't have the permissions to use things outside of it's "sandbox". I'm not really that familiar with Macs, but I'm an IT consultant for my day job. This looks like something I've run into with Linux before. Mac is now based on Unix which is very similar.
You might want to try reinstalling and pay close attention to the prompts. It may be asking you if it has permission to run.
Look here:
https://support.apple.com/kb/PH18894?locale=en_US&viewlocale=en_US
And
http://www.apple.com/osx/what-is/security/
geposted Fri 08 Jul 16 @ 6:47 am
so i made a video to show what I'm talking about.. if this happens while performing live this weekend ..last party i was using finder to locate my music as i did in this video
Check the links I just posted.
Look at the permissions of your drive, music folders, and of the VDJ program and it's associated folders as well.
geposted Fri 08 Jul 16 @ 6:48 am
reinstall VDJ or OS X
geposted Fri 08 Jul 16 @ 6:51 am
vdj say sharing & permissions : i can read and write i did applt to kA contents of this folder just to be sure
same with hard drive and folders ..i can read/write
geposted Fri 08 Jul 16 @ 6:57 am
I meant to reinstall VDJ. Make a backup copy of your VDJ folder, and put it somewhere else. Detach your external hard drive. Then, uninstall VDJ.
After, do a complete shutdown of your system. Probably isn't necessary, but do it for good measure. After about 30sec, start your computer back up. Download a fresh copy of VDJ. Then, install that. Watch as you install it to see if it asks any questions.
After VDJ is reinstalled, run it and login. Poke around to see how things are. Then, close the program. Plug your external hard drive back in and wait a min. Then start VDJ up again. Look around and see how things are. Do your songs load? Do they play? Any issues?
After that, you can start adding skins and plugins back one at a time and test each time.
Finally, if all goes well, go into the backup copy you made of the VDJ folder and add back your history. Try all that out.
geposted Fri 08 Jul 16 @ 7:09 am
oh ok will try that.. gotta party today at 5 tho...after recording the video i realized vdj was downloading ..it updated itself and seems to be moving a bit faster . i will post back results thanks
geposted Fri 08 Jul 16 @ 1:23 pm
update ..party went great ..no problems at all except seems master tempo or something was on although i had i set off ..but i couldn't really control using the slider on my technic 1200 mk2. that was a pain
geposted Mon 11 Jul 16 @ 4:57 pm
