Topic: Traktor Kontrol s2
Hi , I have now bought Virtual DJ 2 and possess the Traktor Kontrol S2 . When I start the program , but nothing happened . What to do and how exactly , so I can use my mixer do I have ? Thank you in advance :-)
Best regards
Alex
geposted Wed 06 Jul 16 @ 10:50 am
VirtualDJ 2?
Where did you buy it from, the latest licensed version is 8.2
geposted Wed 06 Jul 16 @ 11:10 am
oh sry ... i use Virtual DJ 8.2
geposted Wed 06 Jul 16 @ 12:17 pm
Where did you buy it from?
If it was purchased from this website they you should be showing as a licenced user, currently you are not and that may be part of the issue.
You need to log in to the software to authenticate your licence.
geposted Wed 06 Jul 16 @ 12:26 pm
you can because in principle the tractor s2 kontrol at Virtual DJ use 8 ? and if so, do I need a mapping and where can I get this forth , it should do it .
geposted Wed 06 Jul 16 @ 12:44 pm
It is natively supported in 8.2 so no mapping required.
geposted Wed 06 Jul 16 @ 12:51 pm
Traktor Kontrol S2 MKII is indeed natively supported, but not the MKI (original S2).
so if you own the S2 (MKI), nothing will happen of course, as its not supported.
geposted Wed 06 Jul 16 @ 4:38 pm
According to the supported controllers page on Wiki the Mk1 is supported. That's where I checked before responding to the post.
If that information is incorrect then the wiki needs to be changed.
geposted Wed 06 Jul 16 @ 4:57 pm
geposted Wed 06 Jul 16 @ 5:00 pm
