Probably not the best idea to update the day before a gig! Just updated VDJ 8 to the new 8.2. so far -
1. I feel comfortable right now with still using the VDJ 7 skin, in the new 8.2 skin option, I have none. How and where can I download the VDJ 7 skin
2. all my sampler buttons have disappeared - all pads are blank
help!
help!
geposted Thu 07 Jul 16 @ 12:41 pm
I am surprised that an update may have caused you such troubles. An update doesnt delete any files (Samples, Skins etc), so at least the VirtualDj 7 skin should be there.
Have you done a clean installation and deleted files or have you installed VirtualDJ 8 on a different folder than the default /Documents/VirtualDJ ?
Anyways,
If you wish to use VirtualDJ 8 with the version 7 skin (not suggested though), you will have to install VirtualDJ 7 from your Account. It will not affect VirtualDJ 8 and the skin should be available from ver 8 Settings -->INTERFACE tab
alternatively, you may install a custom ver 7 skin from here.. http://www.virtualdj.com/addons/skins.html?category=best&order=default&resolution=all&search=Virtualdj+7
As for your Samples. VirtualDJ 8 Sampler is way different than the version 7 one, and you will have to create Sampler Banks with your Samples, by drag n dropping them to empty slots.
Read more here.. http://www.virtualdj.com/manuals/virtualdj8/interface/browser/sideview/sampler/index.html
Anyways,
geposted Thu 07 Jul 16 @ 1:03 pm
Thanks so much! I only have been playing around with VDJ 8 for about a week, it is great, but rather intimidating! Just need to get through this weekend and then I will have time to tutor myself more and really play with the big boys on VDJ 8.2!!
Much appreciate the quick response for help!!
~ DJ Andrea~
~ DJ Andrea~
geposted Thu 07 Jul 16 @ 1:17 pm
