For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: 8.2 upgrade
I have two MBP, one works pretty good, haven't played with everything yet. The other I just updated, and now VDJ will NOT load. I have re-installed several times, deleted and redownloaded the installer to install fresh. Still nothing. This is my gig MBP. Running OS x 10.11.5. Will try to reinstall VDJ 8 if I can find that build.
geposted Sat 09 Jul 16 @ 3:01 pm
locodogPRO InfinityModeratorMember since 2013
geposted Sat 09 Jul 16 @ 5:25 pm
