Topic: Tags and File names
lurenzfPRO InfinityMember since 2006
I would like to use Virtual DJ 8 to edit and change my files music and video name and song title on my harddrive. If I change the names (tags) in the software will it change the information to the file on the drive? Is there a setting that will do that? Thanks
geposted Sat 09 Jul 16 @ 5:01 pm
If you change the file name in VDJ, it will change the file name on the hard drive. If you change the tag, the file name will remain the same. If you want to change the tag and you want the file to change also, select the dot after the file name (shown) and it will give you the options to change the file name to the tag.
geposted Sun 10 Jul 16 @ 4:24 am
MiandroHome userMember since 2016
How can i disable the option to not read id3 tags. I want the filenames of the mp3 to be like in Explorer in My Computer. I unmark all the options about id tag in settings of virtual 8.2 but is not working. any ideea
geposted Tue 27 Sep 16 @ 9:27 pm
