Topic: 8.2 update
I installed update and now icon for virtual dj is stuck at 68% and won't open... I use a mac - OS X El Capitan Version 10.11.5
geposted Sun 10 Jul 16 @ 2:58 pm
Same issue here with VDJ 8.2.3286 and VDJ 8.2.3291. After installation, the application fails to open and sits at 33%
Mac OS running OS X El Capitan 10.11.5
VDV 8.1.2857 does work
geposted Sat 16 Jul 16 @ 12:41 am
Do you have vdj 7 installed as well?
Can you try to rename settings.xml in your Documents\VirtualDJ folder and start vdj again?
geposted Sat 16 Jul 16 @ 5:59 am
LeanneKHome userMember since 2016
I had the same problem. OS is ElCapitan. Installed Virtual DJ 8.2 then tried to start it but it didn't open. After about 10 minutes I use 'force quit' which showed the Virtual DJ was not responding. Glad to find this thread so I followed the instructions, looked for the settings file in Documents/Virtual DJ, and there was no such file.
However, I decided to try again to open it again so I went to the applications folder, double clicked on Virtual DJ and it opened very quickly this time.
Quite pleasingly it is showing all the files from the default location (desktop). When I had installed from the appstore those files did not show, nor any files when I went through to itunes media. I think I would prefer to use the 'safe' version from app store if it worked. This is my first experience with Virtual DJ
geposted Mon 18 Jul 16 @ 12:17 am
DJ TKOPRO InfinityMember since 2006
It's doing the same thing for me. I tried renaming the settings file to settings1 and it still hangs at 96%. I've tried uninstalling, running disk repair and reinstalling and still doing it. Any suggestions please?
geposted Fri 29 Jul 16 @ 11:23 pm
Renaming settings worked for me, but now all my audio settings are back to default. :( Anyone know how to restore my previous settings? I now see two setting.xml files in my documents. I have the old settings saved in my Time Machine (Mac OS X here).
geposted Mon 01 Aug 16 @ 7:13 am
Just recreate your audio settings. Should not be much work.
But if you want to use your old settings, just rename your backup settings file to settings.xml and delete or rename the current one.
Replacing the time machine settings.xml with your current settings.xml will do it too.
geposted Mon 01 Aug 16 @ 12:04 pm
I have a problem with VDJ 8.2. When i boot my laptop and start vdj for the first time, it makes a crash, heres the report:
Date/Time: 2016-08-01 19:58:13 +0200
OS Version: 10.7.5 (Build 11G63)
Architecture: x86_64
Report Version: 9
Command: VirtualDJ
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Version: 8.2 (8.2.3324)
Parent: launchd [138]
PID: 308
Event: hang
Duration: 1.54s
Steps: 16 (100ms sampling interval)
Pageins: 6
Pageouts: 0
Process: VirtualDJ [308]
UID: 501
Thread 0x13ef DispatchQueue 1
User stack:
16 start + 52 (in VirtualDJ) [0x10ba495c4]
16 main + 289 (in VirtualDJ) [0x10bafaf38]
16 -[NSApplication run] + 470 (in AppKit) [0x7fff8b4f09b9]
16 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135 (in AppKit) [0x7fff8b4f407d]
16 _DPSNextEvent + 1247 (in AppKit) [0x7fff8b4f49c5]
16 AEProcessAppleEvent + 102 (in HIToolbox) [0x7fff87b61b69]
16 aeProcessAppleEvent + 250 (in AE) [0x7fff85eb39f7]
16 _ZL25dispatchEventAndSendReplyPK6AEDescPS_ + 38 (in AE) [0x7fff85eb3b03]
16 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 200 (in AE) [0x7fff85eb3c25]
16 _NSAppleEventManagerGenericHandler + 105 (in Foundation) [0x7fff84f005dc]
16 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 283 (in Foundation) [0x7fff84f0074e]
16 __-[NSAppleEventManager setEventHandler:andSelector:forEventClass:andEventID:]_block_invoke_1 + 101 (in Foundation) [0x7fff84f017c7]
16 -[NSObject performSelector:withObject:withObject:] + 65 (in CoreFoundation) [0x7fff8ea7c541]
16 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 330 (in AppKit) [0x7fff8b4f75b9]
16 -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 242 (in AppKit) [0x7fff8b4f7858]
16 -[NSApplication _sendFinishLaunchingNotification] + 78 (in AppKit) [0x7fff8b4f8b91]
16 -[NSApplication _postDidFinishNotification] + 212 (in AppKit) [0x7fff8b4f8e2b]
16 -[NSNotificationCenter postNotificationName:object:userInfo:] + 65 (in Foundation) [0x7fff84ecafc3]
16 _CFXNotificationPost + 2634 (in CoreFoundation) [0x7fff8ea327ba]
16 __-[NSNotificationCenter addObserver:selector:name:object:]_block_invoke_1 + 47 (in Foundation) [0x7fff84eded0e]
16 -[CAppDelegate applicationDidFinishLaunching:] + 262 (in VirtualDJ) [0x10bafaa6b]
16 CMainWindow::init() + 802 (in VirtualDJ) [0x10bb9a5ea]
16 CThreadEvent::wait(int) + 222 (in VirtualDJ) [0x10bb782fe]
16 __psynch_cvwait + 10 (in libsystem_kernel.dylib) [0x7fff86034bca]
Kernel stack:
16 special_handler_continue + 0 (in mach_kernel) [0xffffff800023be50]
Thread 0x140c DispatchQueue 2
User stack:
16 _dispatch_mgr_thread + 54 (in libdispatch.dylib) [0x7fff86778316]
16 kevent + 10 (in libsystem_kernel.dylib) [0x7fff860357e6]
Kernel stack:
Thread 0x140d
User stack:
16 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff890b5b85]
16 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff86035192]
Kernel stack:
Thread 0x140e
User stack:
Kernel stack:
Thread 0x1410
User stack:
Kernel stack:
Thread 0x1412
User stack:
Kernel stack:
Thread 0x1413
User stack:
Kernel stack:
Thread 0x1415
User stack:
16 thread_start + 13 (in libsystem_c.dylib) [0x7fff890b5b75]
16 _pthread_start + 335 (in libsystem_c.dylib) [0x7fff890b28bf]
16 google_breakpad::ExceptionHandler::WaitForMessage(void*) + 267 (in Breakpad) [0x10ddc9029]
16 google_breakpad::ExceptionHandler::WriteMinidumpWithException(int, int, int, __darwin_ucontext*, unsigned int, bool, bool) + 505 (in Breakpad) [0x10ddc8ea7]
16 _ZL7onCrashPKcS0_Pvb + 215 (in VirtualDJ) [0x10ba62c6d]
Kernel stack:
16 hndl_alltraps + 225 (in mach_kernel) [0xffffff80002da481]
16 user_trap + 711 (in mach_kernel) [0xffffff80002c4017]
16 exception_triage + 149 (in mach_kernel) [0xffffff8000220e15]
16 exception_deliver + 843 (in mach_kernel) [0xffffff8000220c6b]
16 exception_raise + 183 (in mach_kernel) [0xffffff8000249a77]
16 mach_msg_rpc_from_kernel_body + 277 (in mach_kernel) [0xffffff80002239d5]
16 ipc_mqueue_receive + 70 (in mach_kernel) [0xffffff8000215886]
16 thread_block_reason + 299 (in mach_kernel) [0xffffff800022f42b]
16 thread_continue + 1661 (in mach_kernel) [0xffffff800022f1ad]
16 machine_switch_context + 361 (in mach_kernel) [0xffffff80002c2939]
Thread 0x1417
User stack:
16 IThread::staticThreadProc(void*) + 9 (in VirtualDJ) [0x10ba52f35]
16 IThread::threadProc() + 39 (in VirtualDJ) [0x10ba52f61]
16 CVdjUser::thread() + 27 (in VirtualDJ) [0x10baac9b9]
16 CVdjUser::connect(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 1692 (in VirtualDJ) [0x10baad062]
16 CInternet::downloadXML(char const*, char const*, unsigned long, char const*, void**) + 74 (in VirtualDJ) [0x10bc9d0fe]
16 CInternet::downloadString(char const*, char const*, unsigned long, char const*, char const*, char const*, void**) + 297 (in VirtualDJ) [0x10bc9caab]
Kernel stack:
Thread 0x1418
User stack:
16 __select + 10 (in libsystem_kernel.dylib) [0x7fff86034df2]
Kernel stack:
Thread 0x141b
User stack:
16 CInitTask::thread() + 17 (in VirtualDJ) [0x10bb9ab93]
16 CMainWindow::initAsync(CInitTask*) + 279 (in VirtualDJ) [0x10bb9acd1]
16 CPluginEngine::init() + 113 (in VirtualDJ) [0x10bd2aa85]
16 CPluginEngine::selectPlugin(CDeck*, unsigned long, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 53 (in VirtualDJ) [0x10bd2b991]
16 CPluginEngine::selectPlugin(CDeck*, unsigned long, SPluginFile*) + 1169 (in VirtualDJ) [0x10bd30f3d]
16 CPlugin::create() + 1484 (in VirtualDJ) [0x10bd1eb5e]
16 CDeck::getActiveDeck() + 62 (in VirtualDJ) [0x10bbdbcba]
Kernel stack:
Thread 0x141c
User stack:
16 CMainWindow::initAsync(CInitTask*) + 318 (in VirtualDJ) [0x10bb9acf8]
16 CDatabaseEngine::init() + 46 (in VirtualDJ) [0x10bc5fca0]
16 CDatabaseEngine::loadDatabase(int) + 168 (in VirtualDJ) [0x10bc5fdc0]
16 CFile::read(void*, unsigned long, unsigned long) + 29 (in VirtualDJ) [0x10bbe8879]
16 fread + 60 (in libsystem_c.dylib) [0x7fff890afb34]
16 __fread + 234 (in libsystem_c.dylib) [0x7fff890afc41]
16 __srefill1 + 30 (in libsystem_c.dylib) [0x7fff890af166]
16 __read_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff86034d52]
Kernel stack:
Thread 0x142f
User stack:
16 IThread::threadProc() + 49 (in VirtualDJ) [0x10ba52f6b]
Kernel stack:
Thread 0x1431
User stack:
16 HALB_IOThread::Entry(void*) + 78 (in CoreAudio) [0x7fff8407200c]
16 HALC_ProxyIOContext::IOThreadEntry(void*) + 73 (in CoreAudio) [0x7fff84072151]
16 HALC_ProxyIOContext::IOWorkLoop() + 294 (in CoreAudio) [0x7fff84072316]
16 HALC_IOContext_Start + 151 (in CoreAudio) [0x7fff840735b1]
16 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8603367a]
Kernel stack:
Binary Images:
0x10ba47000 - 0x10d022f77 com.atomixproductions.virtualdj 8.2 (8.2.3324) <A353CA17-B56E-3672-A644-7ADC48C2E001> /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
0x10ddc7000 - 0x10ddcdfff com.googlecode.google-breakpad ??? (1.0) <D42A7B6D-B961-3033-8D3A-D40B447F2760> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x7fff8404c000 - 0x7fff840b4ff7 com.apple.audio.CoreAudio 4.0.3 (4.0.3) <9987DC46-2A96-3BA0-B88B-04E573C0AD9B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff84ec8000 - 0x7fff851e1fff com.apple.Foundation 6.7.2 (833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff85eb0000 - 0x7fff85eeffff com.apple.AE 527.7 (527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8601e000 - 0x7fff8603efff libsystem_kernel.dylib ??? (???) <66C9F9BD-C7B3-30D4-B1A0-03C8A6392351> /usr/lib/system/libsystem_kernel.dylib
0x7fff86776000 - 0x7fff86784fff libdispatch.dylib ??? (???) <8E03C652-922A-3399-93DE-9EA0CBFA0039> /usr/lib/system/libdispatch.dylib
0x7fff87b51000 - 0x7fff87e7dfff com.apple.HIToolbox 1.9 (???) <CCB32DEA-D0CA-35D1-8019-E599C8007AB6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff89064000 - 0x7fff89141fef libsystem_c.dylib ??? (???) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
0x7fff8b4ec000 - 0x7fff8c0f2fff com.apple.AppKit 6.7.5 (1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8e9e6000 - 0x7fff8ebbaff7 com.apple.CoreFoundation 6.7.2 (635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Process: Amazon Music Helper [192]
Path: /Applications/Amazon Music.app/Contents/MacOS/Amazon Music Helper
Architecture: i386
UID: 501
Process: AppleSpell [253]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
UID: 501
Thread 0x94b DispatchQueue 1
User stack:
16 ??? (in AppleSpell) [0x10c63fa7c]
16 ??? (in AppleSpell) [0x10c63fd2e]
16 -[NSSpellServer run] + 74 (in Foundation) [0x7fff85024c76]
16 CFRunLoopRun + 95 (in CoreFoundation) [0x7fff8ea2e19f]
16 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8ea1e486]
16 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8ea1ec74]
16 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8ea1650c]
Kernel stack:
16 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
Thread 0x94e DispatchQueue 2
User stack:
Kernel stack:
16 kqueue_scan + 416 (in mach_kernel) [0xffffff800053b4d0]
Binary Images:
0x10c63e000 - 0x10c6faff7 com.apple.AppleSpell 1.7.1 (131.1) <A994D9F1-C4D8-3361-B0F4-112A7BAED8BD> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process: auditd [299]
Path: /usr/sbin/auditd
UID: 0
Thread 0x1386 DispatchQueue 1
User stack:
16 ??? (in auditd) [0x1047d4d84]
16 ??? (in auditd) [0x1047d6608]
16 mach_msg_server + 473 (in libsystem_kernel.dylib) [0x7fff86033274]
Kernel stack:
Binary Images:
0x1047d4000 - 0x1047d7fff auditd ??? (???) <9BDD7E59-6582-362C-BA02-265AED39C42A> /usr/sbin/auditd
Process: autofsd [53]
Path: /usr/libexec/autofsd
UID: 0
Thread 0x18e DispatchQueue 2
User stack:
Kernel stack:
Thread 0x18f DispatchQueue 6
User stack:
16 _dispatch_sig_thread + 45 (in libdispatch.dylib) [0x7fff8677ab1c]
16 __sigsuspend_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff86035022]
Kernel stack:
16 wakeup + 992 (in mach_kernel) [0xffffff8000555e90]
Binary Images:
0x10e446000 - 0x10e447fff autofsd ??? (???) <E0BD130F-E4F9-3CA0-924F-79B3D8491533> /usr/libexec/autofsd
Process: blued [52]
Path: /usr/sbin/blued
UID: 0
Thread 0x179 DispatchQueue 1
User stack:
16 ??? (in blued) [0x1028dd9a4]
16 ??? (in blued) [0x1029144bf]
16 -[NSRunLoop(NSRunLoop) run] + 62 (in Foundation) [0x7fff84ed3e67]
16 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 267 (in Foundation) [0x7fff84ed3f7b]
Kernel stack:
Thread 0x1a4 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x2cd
User stack:
Kernel stack:
Thread 0x1483
User stack:
Kernel stack:
6 workqueue_mark_exiting + 1408 (in mach_kernel) [0xffffff80005a50b0]
Thread 0x1485
User stack:
Kernel stack:
Binary Images:
0x1028dc000 - 0x102995fff blued ??? (???) <FE392F89-6D67-3015-A6AD-BA96C1FB5EFF> /usr/sbin/blued
Process: Bose Updater [196]
Path: /Applications/Bose Updater.app/Contents/MacOS/Bose Updater
UID: 501
Process: com.apple.dock.extra [174]
Path: /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
UID: 501
Thread 0x5e7 DispatchQueue 1
User stack:
16 ??? (in com.apple.dock.extra) [0x10b935474]
16 xpc_service_main + 448 (in XPCService) [0x7fff8e5c65ed]
16 NSApplicationMain + 867 (in AppKit) [0x7fff8b76ceac]
16 _DPSNextEvent + 659 (in AppKit) [0x7fff8b4f4779]
16 BlockUntilNextEventMatchingListInMode + 62 (in HIToolbox) [0x7fff87b5a3fa]
16 ReceiveNextEventCommon + 355 (in HIToolbox) [0x7fff87b5a56d]
16 RunCurrentEventLoopInMode + 277 (in HIToolbox) [0x7fff87b532bf]
Kernel stack:
Thread 0x5ef DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10b934000 - 0x10b938ff7 com.apple.dock.extra 1.0 (1) <681AAFB2-BA8C-31CD-AF2E-7423A349615A> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
0x7fff8e5c4000 - 0x7fff8e5cbff7 com.apple.XPCService 1.3 (1) <68C4DBC9-18C3-3053-96D5-1858B905EAE0> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
Process: configd [14]
Path: /usr/libexec/configd
UID: 0
Thread 0x122 DispatchQueue 1
User stack:
16 ??? (in configd) [0x10e6b7d64]
16 ??? (in configd) [0x10e6b851b]
16 ??? (in configd) [0x10e6b8e20]
Kernel stack:
Thread 0x129 DispatchQueue 2
User stack:
16 __select_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff86034e06]
Kernel stack:
Thread 0x12b
User stack:
16 ??? (in configd) [0x10e6b97fe]
Kernel stack:
Thread 0x135
User stack:
16 ??? (in configd) [0x10e6c4165]
Kernel stack:
Thread 0x1b6
User stack:
Kernel stack:
Thread 0x221
User stack:
16 pppcntl_run_thread + 2194 (in PPPController) [0x10eaf500e]
Kernel stack:
Thread 0x148a
User stack:
Kernel stack:
16 workqueue_mark_exiting + 1408 (in mach_kernel) [0xffffff80005a50b0]
Binary Images:
0x10e6b7000 - 0x10e6e0fff configd ??? (???) <10FEECA6-8BCC-329A-998A-B5D8237E4642> /usr/libexec/configd
0x10eae7000 - 0x10eb26fff com.apple.SystemConfiguration.PPPController 1.7 (1.7) <CCAC9DAA-47D4-3711-9A8D-A1A7C7135CF7> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
Process: cookied [207]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
UID: 501
Thread 0x6d6 DispatchQueue 1
User stack:
16 ??? (in cookied) [0x1088e7eec]
16 _cookied_main + 852 (in CFNetwork) [0x7fff89402c65]
Kernel stack:
Thread 0x6d7 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x1088e7000 - 0x1088e7fff cookied ??? (???) <F08AC6E4-1FB4-3F9C-9EBC-93095E826F91> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
0x7fff89313000 - 0x7fff8947aff7 com.apple.CFNetwork 520.5.3 (520.5.3) <1C11C214-1C70-3358-A709-69C84D999DB8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process: coreaudiod [120]
Path: /usr/sbin/coreaudiod
UID: 202
Thread 0x3cd DispatchQueue 1
User stack:
16 ??? (in coreaudiod) [0x108004314]
16 ??? (in coreaudiod) [0x10806cbcc]
Kernel stack:
Thread 0x3d7 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x3ef
User stack:
16 CAPThread::Entry(CAPThread*) + 98 (in CoreAudio) [0x7fff840934c2]
16 HALRunLoop::OwnThread(void*) + 159 (in CoreAudio) [0x7fff840902df]
Kernel stack:
Thread 0x400
User stack:
16 ??? (in coreaudiod) [0x108076d52]
16 ??? (in coreaudiod) [0x10807085e]
16 ??? (in coreaudiod) [0x1080708ee]
16 ??? (in coreaudiod) [0x108070732]
Kernel stack:
Thread 0x1444
User stack:
16 ??? (in coreaudiod) [0x10800a468]
16 ??? (in coreaudiod) [0x108034cf8]
16 ??? (in coreaudiod) [0x108034cc2]
16 ??? (in coreaudiod) [0x108033b5a]
16 ??? (in coreaudiod) [0x10800a8fc]
16 ??? (in coreaudiod) [0x10800a8d2]
Kernel stack:
15 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
1 hndl_mach_scall64 + 19 (in mach_kernel) [0xffffff80002daec3]
1 thread_set_child + 336 (in mach_kernel) [0xffffff80002aef10]
1 mach_msg_overwrite_trap + 442 (in mach_kernel) [0xffffff800021bcda]
1 ipc_mqueue_receive + 63 (in mach_kernel) [0xffffff800021587f]
1 thread_block_reason + 275 (in mach_kernel) [0xffffff800022f413]
1 thread_go + 608 (in mach_kernel) [0xffffff800022e060]
1 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
1 machine_idle + 289 (in mach_kernel) [0xffffff80002c6461]
Thread 0x1482
User stack:
Kernel stack:
Thread 0x149a
User stack:
Kernel stack:
16 workqueue_mark_exiting + 880 (in mach_kernel) [0xffffff80005a4ea0]
Thread 0x1499
User stack:
Kernel stack:
Thread 0x1497
User stack:
5 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff890b5b85]
5 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff86035192]
Kernel stack:
5 workqueue_mark_exiting + 1408 (in mach_kernel) [0xffffff80005a50b0]
Thread 0x1498
User stack:
Kernel stack:
Binary Images:
0x108003000 - 0x1080c3fff coreaudiod ??? (???) <B845F1F7-2856-3C7B-B471-04FCAB1F9158> /usr/sbin/coreaudiod
Process: coreservicesd [62]
Path: /System/Library/CoreServices/coreservicesd
UID: 0
Thread 0x197 DispatchQueue 1
User stack:
16 ??? (in coreservicesd) [0x10c0abe98]
16 _CoreServicesServerMain + 747 (in CarbonCore) [0x7fff85a9e999]
Kernel stack:
14 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
2 hndl_mach_scall64 + 19 (in mach_kernel) [0xffffff80002daec3]
2 thread_set_child + 336 (in mach_kernel) [0xffffff80002aef10]
2 mach_msg_overwrite_trap + 442 (in mach_kernel) [0xffffff800021bcda]
2 ipc_mqueue_receive + 63 (in mach_kernel) [0xffffff800021587f]
2 thread_block_reason + 275 (in mach_kernel) [0xffffff800022f413]
2 thread_go + 608 (in mach_kernel) [0xffffff800022e060]
2 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
2 machine_idle + 289 (in mach_kernel) [0xffffff80002c6461]
Thread 0x198 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x1c9
User stack:
16 fmodWatchConsumer + 332 (in CarbonCore) [0x7fff85a0f870]
Kernel stack:
16 psynch_cvcontinue + 0 (in mach_kernel) [0xffffff800059e920]
Thread 0x1ca
User stack:
16 read + 10 (in libsystem_kernel.dylib) [0x7fff86035af2]
Kernel stack:
16 hndl_unix_scall64 + 19 (in mach_kernel) [0xffffff80002daea3]
16 unix_syscall64 + 507 (in mach_kernel) [0xffffff80005ce4cb]
16 read_nocancel + 120 (in mach_kernel) [0xffffff80005655c8]
16 write + 209 (in mach_kernel) [0xffffff8000564ec1]
16 get_pathbuff + 3895 (in mach_kernel) [0xffffff8000326827]
16 tsleep + 91 (in mach_kernel) [0xffffff800055610b]
16 wakeup + 632 (in mach_kernel) [0xffffff8000555d28]
Thread 0x1471
User stack:
Kernel stack:
Binary Images:
0x10c0ab000 - 0x10c0abfff coreservicesd ??? (???) <91E520FB-2E13-33C6-ABBC-473AD59A2286> /System/Library/CoreServices/coreservicesd
0x7fff85a02000 - 0x7fff85d1efff com.apple.CoreServices.CarbonCore 960.25 (960.25) <4FC1AB30-022C-3C67-AC46-FDCBFCB7EEDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
Process: cupsd [22]
Path: /usr/sbin/cupsd
UID: 0
Thread 0x15b DispatchQueue 1
User stack:
16 ??? (in cupsd) [0x10104bc00]
16 ??? (in cupsd) [0x101065630]
Kernel stack:
Thread 0x1a9 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x383
User stack:
16 ??? (in cupsd) [0x1010908d9]
Kernel stack:
Binary Images:
0x10104a000 - 0x1010aaff7 cupsd ??? (???) <BDDC4A1B-52EC-309F-BB3D-BB3D82E1F7FB> /usr/sbin/cupsd
Process: CVMServer [109]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
UID: 0
Thread 0x399 DispatchQueue 1
User stack:
16 ??? (in CVMServer) [0x10559e28c]
16 ??? (in CVMServer) [0x1055a38e8]
Kernel stack:
Binary Images:
0x10559d000 - 0x1055a6fff CVMServer ??? (???) <B88C9F5B-FA09-32CF-AA24-F628146BD93A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process: dbfseventsd [222]
Path: /Library/DropboxHelperTools/*/dbfseventsd
Architecture: i386
UID: 0
Process: dbfseventsd [221]
Architecture: i386
UID: 0
Process: dbfseventsd [223]
Architecture: i386
UID: 501
Process: diskarbitrationd [13]
Path: /usr/sbin/diskarbitrationd
UID: 0
Thread 0x121 DispatchQueue 1
User stack:
16 ??? (in diskarbitrationd) [0x106eb339c]
16 ??? (in diskarbitrationd) [0x106eb9e15]
Kernel stack:
Thread 0x12c DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x106eb2000 - 0x106ecdff7 diskarbitrationd ??? (???) <F033F3D5-FF18-37D9-B9BF-59E6D4E30C10> /usr/sbin/diskarbitrationd
Process: distnoted [284]
Path: /usr/sbin/distnoted
UID: 89
Thread 0xeb5 DispatchQueue 1
User stack:
16 ??? (in distnoted) [0x1070a6904]
16 ??? (in distnoted) [0x1070a6c07]
Kernel stack:
Thread 0xeb7 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x1070a5000 - 0x1070a9ff7 distnoted ??? (???) <93233E75-26C5-337E-B191-4F151AF5CF87> /usr/sbin/distnoted
Process: distnoted [144]
UID: 501
Thread 0x496 DispatchQueue 1
User stack:
16 ??? (in distnoted) [0x108f79904]
16 ??? (in distnoted) [0x108f79c07]
Kernel stack:
Thread 0x497 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x146f
User stack:
Kernel stack:
Thread 0x1470
User stack:
Kernel stack:
Thread 0x14a6
User stack:
Kernel stack:
Thread 0x14a7
User stack:
Kernel stack:
Thread 0x14a8
User stack:
Kernel stack:
Thread 0x14a9
User stack:
Kernel stack:
Thread 0x14aa
User stack:
Kernel stack:
Thread 0x14ab
User stack:
Kernel stack:
Binary Images:
0x108f78000 - 0x108f7cff7 distnoted ??? (???) <93233E75-26C5-337E-B191-4F151AF5CF87> /usr/sbin/distnoted
Process: distnoted [18]
UID: 0
Thread 0x137 DispatchQueue 1
User stack:
16 ??? (in distnoted) [0x106577904]
16 ??? (in distnoted) [0x106577c07]
Kernel stack:
Thread 0x138 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x1479
User stack:
Kernel stack:
Thread 0x14b3
User stack:
Kernel stack:
Thread 0x14b4
User stack:
Kernel stack:
Binary Images:
0x106576000 - 0x10657aff7 distnoted ??? (???) <93233E75-26C5-337E-B191-4F151AF5CF87> /usr/sbin/distnoted
Process: Dock [161]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
UID: 501
Thread 0x56e DispatchQueue 1
User stack:
16 ??? (in Dock) [0x103faf25c]
16 ??? (in Dock) [0x103ff570e]
16 __CFRunLoopRun + 1895 (in CoreFoundation) [0x7fff8ea1ef27]
16 __CFRunLoopDoSource1 + 155 (in CoreFoundation) [0x7fff8e9e87eb]
16 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 44 (in CoreFoundation) [0x7fff8e9e8abc]
16 mshPerform + 11 (in HIServices) [0x7fff8e6bffa8]
16 ??? (in Dock) [0x103f28506]
16 ??? (in Dock) [0x103f45f0d]
16 ??? (in Dock) [0x103f776d3]
16 ??? (in Dock) [0x103f79a08]
16 ??? (in Dock) [0x103f7a323]
16 _HandlePopUpMenuSelection7 + 621 (in HIToolbox) [0x7fff87cdd2ac]
16 _ZL19PopUpMenuSelectCoreP8MenuData5PointdS1_tjPK4RecttjS4_S4_PK10__CFStringPP13OpaqueMenuRefPt + 1543 (in HIToolbox) [0x7fff87cdcf78]
13 _ZL15TrackMenuCommonR14MenuSelectDataPh + 1464 (in HIToolbox) [0x7fff87baab5e]
13 _ZL19IsUserStillTrackingP14MenuSelectDataPh + 237 (in HIToolbox) [0x7fff87bab26c]
13 ReceiveNextEventCommon + 355 (in HIToolbox) [0x7fff87b5a56d]
13 RunCurrentEventLoopInMode + 277 (in HIToolbox) [0x7fff87b532bf]
13 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8ea1e486]
13 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8ea1ec74]
13 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8ea1650c]
13 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8603367a]
3 _ZL15TrackMenuCommonR14MenuSelectDataPh + 1605 (in HIToolbox) [0x7fff87baabeb]
1 _ZL31SelectItemAndRestoreAllMenuBitsR14MenuSelectData + 486 (in HIToolbox) [0x7fff87badf60]
1 HIView::SimulateClick(unsigned int, short, unsigned int, short*) + 161 (in HIToolbox) [0x7fff87bef77f]
1 SendEventToEventTargetWithOptions + 72 (in HIToolbox) [0x7fff87b5867a]
1 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 446 (in HIToolbox) [0x7fff87b58840]
1 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1263 (in HIToolbox) [0x7fff87b59234]
1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1703 (in HIToolbox) [0x7fff87b74697]
1 HIView::SimulateClickSelf(short, unsigned int, short*) + 77 (in HIToolbox) [0x7fff87beffab]
1 SendControlSimulateHit(HIView*, short, unsigned int, short*) + 142 (in HIToolbox) [0x7fff87bf4ad4]
1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1874 (in HIToolbox) [0x7fff87b74742]
1 HIStandardMenuView::SimulateHitSelf(short, unsigned int, short*) + 188 (in HIToolbox) [0x7fff87c1e42a]
1 HIMenuView::SimulateHitSelf(short, unsigned int, short*) + 147 (in HIToolbox) [0x7fff87c18cdb]
1 RunCurrentEventLoopInMode + 227 (in HIToolbox) [0x7fff87b5328d]
1 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8ea1e486]
1 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8ea1ec74]
1 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8ea1650c]
1 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8603367a]
1 _ZL31SelectItemAndRestoreAllMenuBitsR14MenuSelectData + 857 (in HIToolbox) [0x7fff87bae0d3]
1 RunCurrentEventLoopInMode + 277 (in HIToolbox) [0x7fff87b532bf]
1 _ZL31SelectItemAndRestoreAllMenuBitsR14MenuSelectData + 881 (in HIToolbox) [0x7fff87bae0eb]
1 _ZL9HideMenusP14MenuSelectDataP9__CFArray + 71 (in HIToolbox) [0x7fff87cd7d3f]
geposted Mon 01 Aug 16 @ 6:02 pm
Thanks. I tried replacing the settings file with the one from my Time Machine, but after doing that, again Virtual DJ wouldn't open. So I trashed it again, keeping the file I renamed 'settings1.xml.' That fixed it. I'll just redo my settings.
geposted Mon 01 Aug 16 @ 7:08 pm
