Topic: Tag Editor 8.2
wigcityPRO InfinityMember since 2004
Tagging multiple files doesn't work any more. 'Error opening file' it says and nothing is written to the fields. This is happening in both 8.2 builds.
geposted Tue 12 Jul 16 @ 4:50 am
I'm not experiencing that issue b3291
geposted Tue 12 Jul 16 @ 6:19 am
I've just rechecked and it does work when I select the tag editor from the context menu. I had been using a key shortcut to 'file_info' which doesn't work as I expected - it does work for a loaded song but not for a selected song, it should be 'browsed_file_info', somehow my mapping changed - I have been fiddling a lot with my settings lately! Thanks for checking, I will close this query. Thanks everyone for the great upgrade!
geposted Tue 12 Jul 16 @ 8:44 am
