Topic: reloop terminal mix 8 / Cue stop
hello everyone I use both VDJ and Serato however while using my reloop terminal mix 8 in Serato and I enter into cue mode and hit the cue Serato won't play the full song which I like. With VDJ when I hit the cue it plays the song which I don't like it won't allow me to drum on the best I want it to cue stop . not cue play
geposted Tue 12 Jul 16 @ 6:05 pm
The CUE button on the Terminal Mix 8 is mapped as cue_stop so it should preview the track as long as its held down. So unless you have mapped that button differently , it should behave like you want it.
Unless you mean the Hotcues buttons. If that is the case, there is a HotCuemode setting in the Options that you change to Stutter
geposted Tue 12 Jul 16 @ 7:56 pm
mines is mapped as cue play how do i change it to cue stop ?
geposted Tue 12 Jul 16 @ 10:04 pm
geposted Wed 13 Jul 16 @ 12:34 am
