Hi all,
in Automix-Mode it is not possible to set a fixed BPM for the List, just fixed percentage of the Pitch.
F.e.: I want a mix in 128 BPM and using tracks with (original) 120-130 BPM, but at the moment the tempo varies between the songs.
It would be great to set the BPM to 128 and the Automix varies the Pitch-Percentage - perhaps only in Dual-Deck-Automix.
Is it possible to set an option, which mix-routine I want to use ?
Best regards,
Ragman
Best regards,
Ragman
geposted Wed 13 Jul 16 @ 2:10 pm
I don't think that's possible with VDJ. However, one thing that you could try is to put your songs into the automix list. Then, sort them by BPM. Depending on the mood, go from slow to fast or fast to slow.
If you do that, then the BPM difference between tracks won't be that noticeable. Once you have your list organized, you can rearrange things a bit. Keep similar BPMs together though. I think it's recommended that you don't make more than a 2-5 BPM difference between tracks.
Hope that idea helps a little.
geposted Wed 13 Jul 16 @ 2:51 pm
Not really, because of the harmonic mixing :-)
That's the reason for the different BPM's.
And that's a wish from me for a future release :-)))
geposted Wed 13 Jul 16 @ 3:04 pm
I think I solved this one a while ago,
raypitman [germany] is the man to ask as he's the one who used the solution, I haven't seen him online for a while
geposted Thu 14 Jul 16 @ 8:03 am
Hey Loco,
I'm still around, but I think that the OP wants the mix to remain at a constant BPM of let's say 128, whereas your super bit of scripting just maintains a constant pitch deviation thru the whole playlist.
With the right settings it's possible to achieve what Ragman is asking for semi manually, but it doesn't work(or at least I havn't found a way of doing it) in AM.
So +1 from me for his suggestion
best
ray
best
ray
geposted Thu 14 Jul 16 @ 10:29 am
Hey Ray,
you're absolutely right. That's what I want :-)
Regards,
Ragman
Regards,
Ragman
geposted Thu 14 Jul 16 @ 10:55 am
+1 on this
geposted Thu 14 Jul 16 @ 11:19 am
so to explain it more clearly, in the hope that the devs can understand what we want(language is often a barrier)
at present in AM(with BPM match enabled) the outgoing track and the incoming track get matched through a combination of BPM + and - in the middle of the transition, but the incoming track returns to its original BPM.
So what is being asked for here is the option to have only the incoming track to match the BPM of the outgoing track(without that changing)
hey presto ... AM fixed at a constant BPM value, and lots of happy campers 'cause I'm sure that I've seen this being talked about a lot on the forum over the years ;-)
geposted Thu 14 Jul 16 @ 1:07 pm
@Ray:
Little correction: At the moment both tracks are going to the Pitch-Percentage in relation of the original BPM of the incoming track.
geposted Thu 14 Jul 16 @ 1:57 pm
@ Ragman
yeah, I think that's the same thing just said in different words LOL
at the end of the day it just comes down to having the new track come in automatically at the exact same BPM of the outgoing track, or have I missed something there?
geposted Thu 14 Jul 16 @ 2:05 pm
@Ray:
Nothing missed :-)
The incoming track has to run completely on the same BPM of the outgoing track.
Nothing missed :-)
geposted Thu 14 Jul 16 @ 2:14 pm
So the config setting autoBPMMatch doesn't keep all the tracks at the same BPM?
geposted Sat 16 Jul 16 @ 7:44 am
no, it will match bpm on load but as the mix starts the incoming track will pitch up or down back to quartz [or as close as it can given the delta and the cross over time] [the out going will also lock to the change]
I've tried a few work arounds [ a rsi script 'fighting' automix with the pitch slider] but I've not found a consistent solution
geposted Sat 16 Jul 16 @ 6:43 pm
Are there any news about that ?
geposted Tue 29 Nov 16 @ 5:04 pm
I'll see what I can can knock up, an new idea is taking root.
geposted Wed 30 Nov 16 @ 1:44 pm
Hi, guys! Since it's been a while since this thread was started, I'd like to ask if there is any progress in this matter that we could hear about? I'm really longing for that automix constant bpm feature... :)
Thx in advance!
Thx in advance!
geposted Mon 25 Dec 17 @ 4:14 pm
I also would like to have a BPM Lock in the automix.
geposted Tue 03 Apr 18 @ 10:47 am
+1
Nice to see this Option in the Future too.
greatings,Dirk
greatings,Dirk
geposted Tue 03 Apr 18 @ 11:22 am
asking since years for it and nothing is goin on ..
there is a script that is doin something, but not beatlocking the tracklist. ( bpm is jumpin up and down )
may someone who has better knowlegde about scripts can do the modification on that one.
var_equal "AMpWA" 0 ? off & set "AMpWA" 1 & repeat_start_instant "AMpitcher" 33ms & load_pulse ? repeat_start_instant "pitchRem" 1000ms 1 & pitch & param_cast & set "AMpitch" : get_var "AMpitch" & param_cast & pitch : blink & set "AMpWA" 0 & repeat_stop "AMpitcher"
http://www.virtualdj.com/forums/201088/General_Discussion/Automix_Compared_to_VDJ7_and_VDJ8.html?search=jiver&page=1
geposted Tue 03 Apr 18 @ 2:15 pm
Still missing in the new version 2018 ...
geposted Thu 26 Jul 18 @ 10:01 am
