Topic: run forward or rewind songs on ddj sz
djgad1PRO InfinityMember since 2008
hay
I have the controller of Pioneer Ddj sz
I updated to version 8.2 and I do not see how I run forward or rewind songs ..
How can I change the settings of the software buttons Fx2 Enc beats will make the movement of the songs forward or backward?
geposted Wed 13 Jul 16 @ 4:34 pm
You can use SHIFT+Jog or the touchstrip. The touchstrip (needle search) has a security function. If the deck is on air then you need to hold down SHIFT first and then use the strip.
geposted Wed 13 Jul 16 @ 4:38 pm
