I added a song to the "Air Horn" sample under Audio FX and need the air horn back! HELP!!!!
geposted Thu 21 Jul 16 @ 1:13 am
I would try to download it from the 'sample' add on section of the website. Or reinstalling the software.
geposted Thu 21 Jul 16 @ 3:13 am
Check your documents/virtualdj/sampler Folder and see if airhorn.vdjsample is still there..it should be there..if so just drag it to the sample list/pad and voila..
Hope that helps
geposted Thu 21 Jul 16 @ 4:51 am
