Topic: 3324 with out the Controller RMX or SX-2
AsTheDJPRO InfinityMember since 2008
geposted Fri 22 Jul 16 @ 2:23 am
Looks like a repeat action is being executed in the background. Some action on the keyboard mapping maybe ? If you restart VirtualDJ and just use mouse to select folders, does it behave like that ?
Try to select the factory default keyboard mapping, then restart VirtualDJ and see if it stops. If it does, then you ll need to check your custom keyboard mapping
geposted Fri 22 Jul 16 @ 4:11 am
CannenPRO InfinityMember since 2016
Also, do you have a key stuck on your keyboard? Dirty mouse?
geposted Fri 22 Jul 16 @ 4:13 am
When I restart VDJ-8.2 it stop that was the only way to get to the music,and no keys were stuck down or the pad I don't use a Ex-mouse Djin.The mapper don't work very well on other skins but the VDJ-8+ skin work all the time.
geposted Fri 22 Jul 16 @ 1:23 pm
This is re-creatable with key press [held] then also pressing [and holding] a modifier key and releasing the initial key, it might not be that but did you at press ctrl, shift alt or alt gr at any point.
geposted Sat 23 Jul 16 @ 7:01 pm
It only did that one time but if I was Djin a gig,Not so good I would have been thinking what if.
geposted Mon 25 Jul 16 @ 1:22 am
