Topic: Rewinding a track 8.2
Since the upgrade to 8.2 if i want to rewind a track to a certain point it sometimes it just keeps going after I've taken my finger off.. This happens randomly not everytime but when it does i have to restart VJ.. Anyone else having this issue?
Also could you tell me how to revert back to 8.1 please as have some gigs coming up and can't afford for this to happen..
Many thanks..
geposted Fri 22 Jul 16 @ 9:26 am
geposted Fri 22 Jul 16 @ 10:21 am
soulboywaxie wrote :
...if i want to rewind a track to a certain point it sometimes it just keeps going after I've taken my finger off.. .
How are you doing this procedure ? Using some controller ? which one and which key ?
Maybe a touchscreen , a custom button on the skin, one of the waveforms of the skin ?
You ll have to provide further info on this.
geposted Fri 22 Jul 16 @ 12:53 pm
My controller is a Denon MC4000 to rewind a track i press and hold shift and - on the pitch bend and + for fast forward, as i said it happens now & again on both decks but only started when upgrading to 8.2.. Hope this is helpful.. Thanks.
geposted Fri 22 Jul 16 @ 6:35 pm
lincol2PRO InfinityMember since 2011
I noticed this too. This is how I solve it: Make sure that the "SHIFT" is the last button released. i.e. pitch bend first and shift second in that pattern.
Hope it helps.
geposted Fri 22 Jul 16 @ 6:48 pm
Will be fixed in next update. In the meantime, indeed the "proper" way is to first release the button prior releasing the SHIFT.
geposted Fri 22 Jul 16 @ 8:05 pm
Thanks Guy's .. Much love to the VJ Massive..
geposted Fri 22 Jul 16 @ 9:49 pm
P.S. Any chance of a Mc4000 Skin as your the daddy when it comes stuff like this.. ;)
geposted Fri 22 Jul 16 @ 9:54 pm
Maybe a related thing here:
If you are trying to move or copy files by holding Shift or CTRL + left mouse button, it'll only move/ copy if you release the mouse button first.
geposted Wed 27 Jul 16 @ 9:43 am
