Ok folks. Even a fresh settings xml and these both sound horrible.
Do I need to remove any errant ini files?
geposted Sun 24 Jul 16 @ 12:11 am
Settings for effects are in Documents\VirtualDJ\Plugins
For the internal effects, you will find them there as native_flanger.ini etc...
geposted Sun 24 Jul 16 @ 6:04 am
I deleted the ini files and it recreated them. All is well again.
geposted Sun 24 Jul 16 @ 7:50 pm
