What is this doing (Karaoke), when selected ?
geposted Sun 24 Jul 16 @ 11:18 am
This option is available for Video Files or Audio Files that you have downloaded lyrics. I suppose the track i see on the pic falls into the 2nd case, correct ?
If this option is enabled, the Track will be marked as Karaoke type and will be shown when the Filter "Show Only Karaoke" from the Browser Options is enabled or use some Filter Folder to gather all of your Karaoke files.
It will also get the Karaoke file icon.
geposted Sun 24 Jul 16 @ 11:40 am
Aha, so this is for the browser filter.
I was using colors as filter before, but this must help the cpu when searching for audio and videofiles :-)
Thank you for the quick reply DjD.
geposted Sun 24 Jul 16 @ 9:11 pm
Also, in VDJ, I would assume that aside from filtering your browser, it will also tell the system to launch the video window.
geposted Mon 25 Jul 16 @ 1:00 am
