Hi Guys,
Got VDJ 8.2 version 3311 Pro infinity, what happens is if i start playing with no internet connection VDJ 8.2 will ask me to login after a while and confirm my license, when i done that my Pioneer SX2 keeps working, but if i logout he wont recognise my Pioneer SX2 again. Tried some things but to no avail, What to do ?
Thank you beforehand :-)
geposted Fri 29 Jul 16 @ 4:17 pm
Don't log out or use the software on more than 2 machines.
geposted Fri 29 Jul 16 @ 4:21 pm
It seems that if i start up i have to login everytime ?
Once logged in no problem.
But what to do if i have a gig where there is no internet connection ?
geposted Sat 30 Jul 16 @ 2:40 am
check your config/options under internet. Everything is there.
or a quick search and type LOG
under internet it should display 3 things and answer it as N/Y/Y
geposted Sat 30 Jul 16 @ 3:28 am
Ok resolved. Thank you guys
geposted Mon 01 Aug 16 @ 10:07 pm
how do i get the ddjsxs hot cue pads to light up colored when cue pad is pressed .
geposted Tue 29 Nov 16 @ 1:37 am
I'm DJ BlackAfrican, I bought numark party mixer with out a lisence it works only 10 minutes how can I get lisence.
geposted Tue 06 Feb 18 @ 9:18 am
geposted Tue 06 Feb 18 @ 10:29 am
You are posting to a topic with different subject, but short answer is ..
Numark PartyMix comes with a VirtualDJ LE license, which allows you to use VitualDJ with limited features but no time limitations. If your unit didn't come with a VirtualDJ LE serial please contact the store or Numark Support and claim one.
For any other assistance please do not reply here, contact our Support or open a new topic with a relative title/subject
geposted Tue 06 Feb 18 @ 12:38 pm
I use the app but recently it can't play its requesting for an analog mixer license
geposted Thu 26 Apr 18 @ 8:28 pm
geposted Wed 19 Sep 18 @ 5:31 pm
how to get license
geposted Tue 23 Oct 18 @ 7:53 pm
Post above your one
geposted Tue 23 Oct 18 @ 8:42 pm
gabipaunescu wrote :
Key please for virtual 8?
geposted Thu 21 Mar 19 @ 2:16 am
DJZOOTYONHP wrote :
Hi Guys,
i subscribe monthly subscrtion but they send me message that they is a email i will go comfirm plz i need help
geposted Fri 24 May 19 @ 4:27 pm
hello i have virtual 8.2 and i do not know rx2 controller what to do
geposted Thu 03 Jun 21 @ 7:28 pm
i sit at home and enjoy my massive music collection bought a pioneer dj sb3 controller. purchased a liscence for home essentials. after about an hour i got to reboot the fn thing. i would have bought a pro lisc but if the damn thing dont work why spend more money. if i have a party i got to tell my guest to hold on for 30 minutes till i reboot the shitty software. any suggestions before i have to go purchase serato software
geposted Fri 04 Jun 21 @ 11:51 pm
