For example, I change the latency setting, hit apply and the songs stops for a second and then plays. Why doesn't hitting apply cause this to happen? Thanks
geposted Tue 02 Aug 16 @ 12:23 am
when the Audio configuration changes and APPLY needs to be selected in order the new setup to be applied, it re-initializes /re-connects to the Sound card. Apparently this is something that you dont do "live"
geposted Tue 02 Aug 16 @ 12:58 am
Remapp a keys you don't do live also, the sound cut off for 2-3s when I was remapping
geposted Tue 02 Aug 16 @ 12:58 pm
Re-,mapping shoudnt affect sound. When you change something in the mapping, the mapping is reloaded, (notice that the ONINIT and ONEXIT keys appear in the Key Learn box), but the sound-card shouldnt re-initialize.
geposted Tue 02 Aug 16 @ 5:42 pm
in VDJ 8.1 there were no sound drop out when mapping Live ,but now there is in VDj- 8.2 so now mapping when play gigs only before the gigs or after ?
geposted Tue 02 Aug 16 @ 11:58 pm
